mikex24
- 87
I am trying to prove that a body because of the sun radiation and ''greenhouse effect'' gets very hot.
The body is based on the surface of the Earth but because of trapped radiation it get hotter as the time passes. This is my first thinking to solve that problem. I find that the temperature of the Earth surface is approx. 298K and i am trying to find the temperature of the body in the air which is inside of it. Body is made of bronze. I was thinking that the radiation from the sun radiated the Earth surface and then by air convection transfer heat in the inside of my body and therefore transfer heat to the outside surface of the body. But the only data that i have is the material and body dimensions. Also i have found that Earth surface temperature is 298K. Is this the right way or is something different from this? I also think a different case than this which is that the radiation hit on the surface of the object and the it radiate the body and the inner air of that body. Which is the right way to solve it?
