Proving the Recursive Formula for an Using Induction
  • Thread starter Thread starter IntroAnalysis
    Induction
IntroAnalysis
Define an = (an-1 + an-2)/2 for each positive integer ≥ 2. Use induction to show that: an+1 - an = (-1/2)n(a1 -a0)
First show it is true for base case. Assume if it is true for (k), then show it is true for (k + 1).
Base case n=1. Then a2 - a1 = (-1/2)1(a1 - a0) = (a0 - a1)/2
Check: a2 - a1 = (a1 + a0)/2 - a1 = (a1 + a0 - 2a1)/2 = (a0 - a1)/2.
So then do I assume that ak+1 - ak = (-1/2)k(a1 - a0)? Then what?
so assume it is true for k-1,k as below (note you had the power wrong above)
a_k - a_{k-1} = (-1/2)^k(a_1 - a_0)
Now using that can you show
a_{k+1} - a_{k} = (-1/2)^{k+1}(a_1 - a_0)
No, I did not have the power wrong. This is from Introduction to Analysis, Gaughan, Prob. 23.
It says you may want to use induction to show that:
an+1 - an = (-1/2)^n(a1 - a0).
Got the induction part:
Assume ak+1 - ak = (-1/2)k(a1-a0), then
ak+2 - ak+1 = (ak+1 + ak)/2 -[(-1/2)k(a1 - a0) + ak]
= (ak+1 + ak - 2ak)/2 - [(-1/2)k(a1 - a0)]
= (ak+1 - ak)/2 - [(-1/2)k(a1 - a0)]
= (1/2)(-1/2)k(a1 - a0) - [(-1/2)k(a1 - a0)]
= -(-1/2)k+1(a1 - a0) - [(-1/2)k(a1 - a0)]
= (-1/2)k(a1 - a0)[1/2 - 1] = (-1/2)k+1(a1 - a0) as desired.
The rest of the proof uses Triangle Inequality Theorem.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
