Proving the Riemann-Lebesgue Lemma for Cosine and Infinite Integrals
  • Thread starter Thread starter kingwinner
kingwinner
Riemann-Lebesgue Lemma:
If g is piecewise continuous on the interval [a,b], then
b
∫ g(t) sin(ωt) dt -> 0 as ω->∞
a
[this is quoted directly from my textbook]
(i) Now assuming this result, is it possible to prove from this result that
b
∫ g(t) cos(ωt) dt -> 0 as ω->∞ ??
a
I think it also works for cosine becuase cosine is just a horizontal shift of sine, but does this imply that the second result(with cos) is an immediate consequence of the first(with sin)? How can we prove this?
(ii) Also, if we have
, is the lemma above still true?
N/A
Any help is appreciated! :)
Well, can we prove it by shifting horizontally?
Sure, there are some issues -- but maybe we can prove those issues converge to zero?
(WLOG, we can assume g is actually continuous)
(i)
b
a
implies
b
∫ g(t) cos(ωt - pi/2ω) dt -> 0 as ω->∞
a
But from here, how can we prove that
b
a
Is there absolutely nothing you can think to do to that integral or that integrand?
There is a really short solution to this via step functions, but if you don't have that available, then you can use cruder estimates. As Hurkyl mentioned, we may assume g is continuous. Understanding why this doesn't change the problem is the key to figuring out a good first step. Remember sectionally continuous just means continuous except for a finite number of jump discontinuities, and we can certainly take the definite integral over a continuous interval with discontinuous endpoints, since the endpoints don't really matter.
You have an integrand that is the product of two functions. There is a way to rewrite that integral, by splitting up the parts.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
