Proving the superposition principle
bleucat
Hi everyone.
I am trying to prove the superposition principle for linear homogeneous equations, which states that if u(t) and w(t) are solutions to y' + p(t)y = 0, then u(t) + w(t) and k(u(t)) are also solutions for any constant k.
I substituted (u + w) in for y, but how does that help me?
Thanks in advance for the help!
Use the fact that u(t),w(t) satisfy the ODE.
As in, what differentiation property makes u + w a solution if u, w are?
The statement u(t),w(t): solutions of the ODE means
u'(t)+p(t)\,u(t)=0, \, w'(t)+p(t)\,w(t)=0
Put y'(t)=u'(t)+w'(t) in the original ODE and use the above equations.
Hah, I got it. That wasn't bad at all.
Thanks!
Now, can you do it for ku(t)? And, can you prove that those two together show that
au(t)+ bv(t) is a solution for any numbers a, b, as long as u(t) and v(t) are solutions?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
