I Pseudo-Riemaniann isometries
cianfa72
TL;DR Summary
About the isometries of pseudo-riemannian manifolds and the definition of manifold isotropic around a point
I'd ask for clarification about the symmetries of (pseudo) Riemannian manifold ##M## of dimension ##n##.
The set of smooth vector fields ##\Gamma(TM)## forms a vector space over ##\mathbb R##; the commutator defined as $$[X,Y](f):=X(Y(f)) - Y(X(f))$$ turns it into a (infinite dimensional) Lie algebra.
Consider the set of continuous isometries, i.e. the flows of Killing Vector Fields w.r.t. the tensor metric ##g##. KVFs form a linear subspace of ##\Gamma (TM)## that closes w.r.t. the commutator, i.e. it is a Lie algebra on its own. As far as I can tell, this linear subspace/Lie algebra over ##\mathbb R## has always finite dimension ##m \geq n##.
That said, consider for instance the case of spherically symmetric Lorentzian metric. It has a specific Lie algebra of rotational KVFs. The latter should be a linear subspace/Lie algebra of the Lie algebra of all KVFs.
Now the question: does the definition of isotropy around a point apply to the entire spacetime as manifold or to its spacelike submanifolds ?
I took as definition of isotropy around a point the one from J. Lee - Introduction to Riemannian manifolds" chapter 3 - Symmetries of Riemannian Manifolds.
Lee's definition of isotropic at a point is in the context of Riemannian Geometry where there isn't a time dimension typically per se so it applies to the entire tangent space at a point. Maybe other authors have different conventions in the context of pseudo-Riemannian geometry.
https://math.stackexchange.com/questions/4613275/are-3-dimensional-einstein-manifolds-isotropic has a definition of isotropic in the semi-riemannian case. Basically non-null tangent vectors at a point of the same length must have an isometry that maps one to the other.
This has some interesting cases. For instance a vector whose spatial components are greater than their time components would have to be map into a pure spatial vector with no time component. Locally these are basically the symmetries of the Lorentz group.
S .Carroll in his book "Spacetime and geometry" section 8.1 defines a manifold isotropic around a point ##p## if for any ##V,W \in T_pM## there exists an isometry ##\theta_p## in the subgroup of isometries that leave fixed ##p## and ##k \in \mathbb R## such that $$\theta_p^*(W)=kV$$ where ##\theta_p^*## is the pushforward associated to ##\theta_p## evaluated at ##p##.
I believe in this case the relevant manifold ##M## to which the notion of isotropy applies isn't the spacetime as whole but its spacelike hypersurfaces (which are Riemannian manifolds of their own).
In that link I believe the relevant condition isn't on the isometry ##\theta_p## fixing the point ##p## by itself, but on its associated pushforward ##\theta_p## at ##p##. It applies to the same type of non-null vectors in tangent space (i.e. either spacelike or timelike).
I glanced at Carroll and it appears that he is talking about a specific foliation of spacetime with the requirement that the submanifold spatial leaves are isotropic. However, he notes that a different non-comoving observer, i.e., a different foliation would not find their leaves also isotropic.
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
