Psychometry question- on where to begin?
  • Thread starter Thread starter santeria13
The discussion focuses on a psychrometric problem involving an air-conditioning unit where moist air and dry saturated steam interact. The main challenge is determining the specific humidity and temperature of the air entering the unit, given the exit conditions and steam flow rate. Participants clarify that the term "unit" refers to the humidifier and emphasize the need to understand specific humidity and enthalpy calculations. The importance of mixing the incoming moist air with the steam to find the final product's properties is highlighted. Overall, the conversation seeks guidance on setting up the problem using psychrometric principles and relevant equations.
santeria13
Moist air leaves the humidifying unit of a “winter” air-conditioning plant at a rate of 0.6 m3 /s. The air has a temperature of 30°C and is 60% saturated. Dry saturated steam at 100°C is supplied to the unit at a rate of 7.015 g/s. Determine the specific humidity and temperature of the air entering the unit, assuming that the pressure is 1.01325 bar throughout.
steady flow equations e/g -Qin = ma(H2-H1) etc..
psychometric chart analysis
3. The Attempt at a Solution
I usually am comfortable solving such questions however do not know how to set it up in order to begin. I am confused by the use of the word unit and have never seen a question on an air conditioning system that gives me the value of temperature and mass flow rate of steam entering the humidifier. Isn't it the steam that humidifies the air and usually in these types of questions the temperature and relative humidity of the air/water entering the system and leaving the system are given however in this case theyre only given for the water leaving and for the steam that humidifies the air into water. I have no idea how to incorporate or make use of the steam values, nor can i find any similar examples on youtube or google, and would greatly appreciate anyones input. My problem here is where to begin rather on how to solve the whole question.
I know psychometry has to be used but I don't understand what to do with the steam values as I have never seen a question that uses them instead of the values of temperature/relative humidity and mass flow rate of the air entering the system
Psychometry is a psychic phenomena, and psychometrics is the discipline of psychological measurement. Might just be splitting straws here but it could turn out to be relevant.
Aha! "Not to be confused with psychrometrics, the measurement of the heat and water vapor properties of air."
Humidity is the amount of water vapor present in a sample of air. The incoming air has a certain percentage of water vapor already contained in it, and additional water vapor is being added in the form of 'dry' saturated steam, which means that this steam is composed of 100% water vapor. If you thoroughly mix the two streams, that is, the incoming moist air mixed with the steam, what is the specific humidity and temperature of the final product? You do have to understand what the term 'specific humidity' means in this context. You'll also need to know the enthalpies of the air and the steam in order to find the final temperature of the mixture.
"Unit" means the humidifier. The word "unit" is used for any arbitrary piece of processing equipment.
You have two streams entering the humidifier, and one stream exiting. The first step is to characterize the exit stream. I assume your tables give you the specific volume and specific enthalpy of 30 C air at 1 atm and 60% saturation, correct? If you know the specific enthalpy, what is the mass flow rate? What mass flow rate of bone dry air and of water does this imply? What is the rate of enthalpy exiting the unit?
Next, characterize the inlet stream of steam.
Chet
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
