Geremia
- 150
- 0
Does Ptolemy's theory of epicycles mathematically reduce to Kepler's 3 Laws in the limit of the number of epicycles tending to infinity? Thanks
There is a very good article on JSTOR:Geremia said:Does Ptolemy's theory of epicycles mathematically reduce to Kepler's 3 Laws in the limit of the number of epicycles tending to infinity? Thanks
Actually, "[URL Power of Epicyclical Astronomy (Hanson).pdf"]Hanson's Isis article[/URL] shows that you don't need an infinite number of epicycles to reproduce an elliptical orbit.DrStupid said:Yes, but today we would call it Fourier series.
Kepler's laws were an approximation to Ptolemy's epicycles. How are Ptolemy's epicycles "wrong"?Chronos said:Ptolemy's epicycles was a very good description, but, wrong. You can't make wrong better with math.
No, it doesn't.Geremia said:Does Ptolemy's theory of epicycles mathematically reduce to Kepler's 3 Laws in the limit of the number of epicycles tending to infinity? Thanks
D H said:What you have left can describe any cyclical path, and with generalizations, any closed path whatsoever. This is not a falsifiable description; it is not scientific.
Empirical laws can come in very handy at times. Kepler's laws are an empirical model, for example. Another example is the JPL Development Ephemerides, a set of piecewise continuous Chebyshev polynomial coefficients that one can use to compute the positions and velocities of the planets at some point in time. While highly empirical, those polynomial coefficients are generated by a highly theoretical model.DrStupid said:Empirical approximations (e.g. Shomate equations for thermodynamic properties or virial expansions for real gases) belong to the standard methods of science.
D H said:The Ptolemaic model offers no such insight.
It certainly does not apply to all empirical models. Some do provide very deep insight. I mentioned one such empirical model already: Kepler's laws. That gravitation is an inverse square law can be and was derived from Kepler's laws. Another is Planck's law, the original form of which was u(f,T) = af^3/(\exp(bf/T)-1). The a and b were empirical values. Later modifications to Planck's law related those empirical constants to Boltzmann's constant and to quantum mechanics.DrStupid said:This also applies to all empirical models, but that doesn't necessarily mean that they are not scientific.
There is no computational advantage in doing so. Such a model is rather disadvantageous compared to other empirical and semi-empirical models of orbits.Therefore it should also be acceptable to use epicycles for the approximation of orbits.
D H said:There is no computational advantage in doing so.
Kepler's laws were anything but an approximation to Ptolemy's epicycles. Ptolemy's epicycles were laden with many problems. The discrepancies between model and reality became more apparent as observations improved over time. There is a huge difference between tracing out the path of a planet over time, as Ptolemy (and later Hanson) did, and tracing out the path of a planet in time, as Kepler did.Geremia said:Kepler's laws were an approximation to Ptolemy's epicycles. How are Ptolemy's epicycles "wrong"?
Ptolemy's epicycles were not Fourier series. The frequencies in a Fourier series are highly constrained. Fourier series "work" because the underlying functions are orthogonal. This orthogonality does not arise if one picks random frequencies, which is how the Ptolemaic epicycles were built up over time. Ptolemy started with some gross behaviors that were known to the ancients. Others added on to these, but there was no Fourier formalism in their ad hoc additions.DrStupid said:Yes, but today we would call it Fourier series.
First off, these scientists never once mentioned the term epicycles. They did not use Ptolemy's epicycles. They used Fourier analysis.DrStupid said:There are scientists that do not agree in this opinion (e.g. http://articles.adsabs.harvard.edu//full/1979ApJ...234..275M/0000275.000.html)
If youGeremia said:Does Ptolemy's theory of epicycles mathematically reduce to Kepler's 3 Laws in the limit of the number of epicycles tending to infinity? Thanks
