Pull-off force: hose, pipe, clamp
A recent study tested the pull-off force of a hose and pipe connection at a 10% reduction in clamp torque, revealing negligible changes in results. The discussion highlights concerns that higher torque might deform the soft plastic pipe, reducing friction between the hose and pipe. However, it is noted that minimal initial clamping is sufficient to initiate positive feedback, and excessive torque is unnecessary. The assembly differs from previous studies by focusing on clamp torque rather than position and involves a plastic pipe without grooves. Overall, the findings suggest that effective clamping is crucial to prevent fluid penetration without needing excessive torque.
jbenedet
Was surprised by a study recently where we tested 6 samples for pull-off force at a 10% reduction in clamp Torque and noticed negligible shift in results. Is it possible that at higher torque the clamp is deforming the pipe, reducing the surface contact (friction) between the hose and pipe?
The pipe is a soft plastic, the hose is rubber, the clamp is steel. The pipe is inserted into the hose and a clamp is torqued down over the connection.
It’s similar but different. This is a study focused on the torque of the clamp. The other was for clamp position. This assembly also has no groove unlike the other example and is a plastic pipe, instead of a steel pipe. I am being careful not to provide proprietary information while still including enough info to work through the concept. Also, the community provided good ideas/brainstorming based on the info I provided previously. It was helpful. Thanks.
Do your managers know that you are having to resort to Internet forums to do your proprietary work? Are you working as an ME?
This is so incredibly out of line it’s ridiculous. I’m not “resorting” to anything. I’m thinking about this because I enjoy it, not because I can’t get my work done.
It is often the case that you can more easily push a hose on, or off a pipe, but you cannot pull it off. When you pull on a hose, the tension causes the hose becomes slightly longer, while the diameter of the hose is reduced. The surface area of the hose effectively remains constant. That is the source of the positive feedback.
The hose must be clamped sufficiently to the pipe, that the internal fluid under pressure, does not penetrate between the pipe and the hose, under the band of the clamp.
No.
Very little initial clamping is necessary to start the positive feedback multiplication. Once the clamp is snug, additional clamping will be unnecessary.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
