I Pullback & orthogonal projector
ergospherical
Education Advisor
Insights Author
We have a map ##\phi : M \rightarrow N##, where ##N## has dimension ##n## and ##M## has dimension ##m=n-1##. So we consider the hypersurface ##\Sigma \equiv \phi(M)## picked out by the map. We also have an orthogonal projector, ##{\bot^a}_b \equiv \delta^a_b + n^a n_b##, where ##n## is the unit normal to ##\Sigma##.
The exercise is to just verify that the expected properties hold, i.e. that
(i) for a vector ##V##, that ##\phi_{\star} V = \bot (\phi_{\star} V)##
(ii) for a ##(0,s)## tensor ##\omega##, that ##(\phi^{\star} \omega) = \phi^{\star}(\bot \omega)##
(iii) for a ##(r,0)## tensor ##T##, that ##\phi_{\star} T = \bot(\phi_{\star} T)##
I can reason for (i) - i.e. that since ##V## is the tangent vector to a curve ##\lambda : I \rightarrow M##, and the push-forward curve ##\phi \circ \lambda : I \rightarrow N## must lie completely in ##\Sigma##, so ##\phi_{\star} V## must be tangent to ##\Sigma##. So ##n_b (\phi_{\star} V)^b = 0## and:$${\bot^a}_b (\phi_{\star} V)^b = (\phi_{\star} V)^a + n^a n_b (\phi_{\star} V)^b = (\phi_{\star} V)^a$$For (ii), I'm missing a step or two. I would start just from the basics,\begin{align*}
(\phi^{\star} \omega)(X_1, \dots, X_s) &= \omega(\phi_{\star} X_1, \dots, \phi_{\star} X_s) \\
&= \omega( \bot (\phi_{\star} X_1), \dots, \bot (\phi_{\star} X_s) )
\end{align*}What next? I can't use the same reasoning as before to argue that ##\phi^{\star} \omega## is tangent to ##\Sigma##, because ##\omega## isn't obtained from a push-forward of a curve (it's instead defined by its action on vectors). Any ideas...?
What kind of manifolds are M and N? In a Riemannian manifold I would expect a minus sign in the orthogonal projection. In a pseudo-Riemannian one I would expect it to depend on the nature of ##n##.
I can reason for (i) - i.e. that since ##V## is the tangent vector to a curve ##\lambda : I \rightarrow M##, and the push-forward curve ##\phi \circ \lambda : I \rightarrow N## must lie completely in ##\Sigma##, so ##\phi_{\star} V## must be tangent to ##\Sigma##. So ##n_b (\phi_{\star} V)^b = 0## and:$${\bot^a}_b (\phi_{\star} V)^b = (\phi_{\star} V)^b + n^a n_b (\phi_{\star} V)^b = (\phi_{\star} V)^b$$
Yes.
For a one-form ##\omega## and a vector ##X## in ##N##, write out ##\omega(\perp X)## on component form. What do you notice? What happens if you do this with (0,s) tensor?
You're right that I didn't fully specify the problem - more generally ##{\bot^a}_b = \delta^a_b \pm n^a n_b## where +/- holds for ##\Sigma## space/time-like. In this case I have assumed a sub manifold which is everywhere space like.
r.e. your answer, just considering a one-form for brevity,\begin{align*}
\omega( \bot(\phi_{\star} X)) &= \omega({\bot^a}_b (\phi_{\star} X)^b e_a) \\
&= {\bot^a}_b \omega_a (\phi_{\star} X)^b \\
&= (\bot \omega)_b (\phi_{\star} X)^b \\
&= (\bot{\omega})(\phi_{\star} X) \\
&= \phi^{\star} (\bot \omega)(X)
\end{align*}
And the generalization to an (0,s) tensor is straightforward due to multi linearity. For some reason I was getting confused about setting ##(\bot \omega) \equiv \bot(\omega)##. Obviously that's how it's defined...!
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
