Pulleys and Mass becoming infinitely large
  • Thread starter Thread starter puma7
    Mass Pulleys
The discussion revolves around a physics problem involving a 100kg man and a 50kg mass connected by a pulley. The first part of the problem, which was solved, calculated the tension in the rope. The second part raises the question of the man's acceleration as the mass becomes infinitely large, with initial thoughts suggesting infinite acceleration. However, it is clarified that regardless of the mass's increase, the man's acceleration cannot exceed gravitational acceleration (g), leading to the conclusion that it approaches g as the mass approaches infinity. The conversation emphasizes the importance of analyzing the problem from different perspectives to understand the underlying physics better.
puma7
This is 2 problems that continue one another; I solved the first one but do not understand the second.
A 100kg man dangles a 50kg mass from the end of a rope. If he stands on a frictionless surface and hangs the mass over a cliff with a pulley, the tension in the rope will be: (Note: Ignore any frictional forces) [SOLVED]
In the question above, as the mass becomes infinitely large, the man's acceleration becomes:
A. 5m/s2
B. 10m/s2
C. 20m/s2
D. infinite
F = ma
The solution to the first problem:
50g = (50+100)a
a = g/3 ~ 3.33
T = mass of man (a) = 100(3.33) = 333N
For the second problem:
Now the acceleration is directly tied to the mass of the block, so when it becomes infinite, I think the acceleration should be infinite.
However, in the answers it says: "B is correct. No matter how large the mass gets, its acceleration can never be greater than g, because it is gravity that is acting on it. Of course, the man will not be accelerated faster than the mass."
They go on to repeat this method again in the next problem. I don't really understand how the man's acceleration would still be finite with a block of infinite mass.
50g = (50+100)a
a = g/3 ~ 3.33
Good.
Not good. Redo this.
Forget the rope and the 50 kg mass for a second. If the man just dropped, what would be his acceleration? If his mass doubled, what would change? What if he were 1000 kg, not 100 kg?
Instead of trying to do it 'in your head', just redo your first calculation with increasing mass and see what happens. Make his mass first 100 kg, then 1000 kg, then 10000 kg. See the pattern.
If the man just dropped, then mg = ma and a = g. I see how acceleration will approach g as the mass goes to infinity now.
What do you mean redo this? If you do it from the perspective of the block, then
mg - T = ma
T = mg - ma = 50(10 - 3.33) = 333N
Cool.
mg - T = ma
As applied to the block, that equation has a sign error. The tension and acceleration are both upward.
Mg-T=Ma
T=ma
a=(\frac {M}{M+m}) g
M>>m, M+m≈M
azizlwl said:
Mg-T=Ma
T=ma
M>>m, M+m≈M
Your second and third equations are incorrect.
But I agree that the best way to see the answer is to solve it symbolically and let M → ∞.
Why not let the OP solve it?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
