Pump has a suction lift of more than 10.3 m
In summary: Quick clarification; from a practical standpoint we often consider the suction pressure to be negative, but for this problem it probably helps to use absolute pressure, which can only be positive (save for the tiny effect of intermollecular forces). Either is fine as long as the OP understands that "pull" is more a colloquialism than a physical reality.If the centrifugal pump here is designed for water only then it is unlikely the level of water in the suction pipe will rise even a meter. Try getting a centrifugal pump to prime in this manner even with only a meter of lift. It is all but impossible. Once the pump is primed things are different and it will work.
suryanarayan
As I was going through a course on Hydraulics, there was a brief explanation about how the atmospheric pressure can only support a water column of 10.3 m.A few more points that are prerequisite to the discussion are as follows
1)A fluid cannot be pulled;it has to be pushed.
2)A centrifugal pump's impeller ,on rotation,throws fluid away from the eye(due to the centrifugal force) and creates a partial vacuum at the eye.
So ,consider the following situation given in the figure
The experiment is conducted in normal atmospheric conditions
1)We fill the suction side and the discharge with water completely.This is possible because the check valve prevents the fluid from escaping.Now the impeller is completely immersed in water.
2)The pump is started runs at a very high rpm.
What is going to happen in the situation?
My thoughts are as follows:
The impeller throws the fluid to the discharge ,partial vacuum is created at eye,the check valve opens and since the weight of the water column is higher than what the atmospheric pressure can hold,the water drains to the tank.This creates a flow discontinuity in the suction side.
Will that be the case or will something else happen?
Hi,
that valve opens only if the pressure outside is higher than inside. That never happens: the pump can't go further than 'zero pressure' at the inlet of the pump.
The purpose of the check valve is to prevent flow down the pipe and your answer as the water flows down the pipe?
What I see happening here is essentially nothing: when you turn on the pump, the water expands a little until the pump starts cavitating.
suryanarayan said:
...since the weight of the water column is higher than what the atmospheric pressure can hold...
Since this the foot valve will remain closed. In this setup if the suction leg is full then there is no way that valve will ever open.
I think you misunderstand. It can be pulled a little, but if water is pulled more than about 10m it begins to boil and turn into a gas. That causes what @russ_watters mentioned, as "pump cavitation" But you can use a pump to suck water up 1m, no problem.
Likes sandy stone
Related to Pump has a suction lift of more than 10.3 m
1. What is the definition of suction lift in a pump?
The suction lift of a pump refers to the maximum height that the pump can lift water from a source, such as a well or tank, up to the pump's intake port. This distance is measured in meters or feet and is an important factor in determining the pump's performance.
2. Why is a suction lift of more than 10.3 m significant?
A suction lift of more than 10.3 m is significant because it indicates that the pump has a strong ability to pull water from a water source, even if the source is located at a higher elevation than the pump. This is important in situations where the water source is not located directly below the pump, or if the pump needs to be located at a higher elevation than the water source.
3. How is the suction lift of a pump determined?
The suction lift of a pump is determined by the manufacturer and is typically listed in the pump's specifications. This measurement is based on the pump's design, motor power, and other factors that affect its ability to lift water. It is important to consult the manufacturer's specifications to ensure that the pump's suction lift is suitable for the intended application.
4. Can a pump with a suction lift of more than 10.3 m be used for all types of liquids?
No, the ability of a pump to lift liquids depends on the specific gravity and viscosity of the liquid. A pump with a suction lift of more than 10.3 m may be able to handle water, but it may not be suitable for pumping thicker or heavier liquids. It is important to consult the manufacturer's specifications to ensure that the pump is suitable for the type of liquid being pumped.
5. What are some factors that can affect the suction lift of a pump?
The suction lift of a pump can be affected by various factors, such as the type of liquid being pumped, the temperature of the liquid, the elevation of the water source, and the condition of the pump's components. Additionally, the length and diameter of the suction pipe can also impact the pump's ability to lift water. It is important to consider these factors when selecting a pump with a specific suction lift requirement.
  • Mechanical Engineering
  • Chemistry
11K
