Pump with intake and compression using different pressure ratios
The discussion revolves around the mechanics of using different pressure ratios in a pumping system with a larger and smaller cylinder. It highlights the importance of isothermal and adiabatic compression, emphasizing that isothermal processes must occur at low speeds to minimize friction and leakage losses. The conversation points out that achieving true isothermal or adiabatic compression is impractical, and efficiency calculations must account for heat exchange and temperature changes during the process. A significant challenge is maintaining the large cylinder's temperature to avoid negative work output, particularly when dealing with large volume discrepancies. Overall, the design must balance efficiency, costs, and operational conditions to optimize performance.
goran d
Lets say we got a larger cylinder-piston combo and a smaller one.
First we move the larger cylinder, filling in with vacuum. Then we pump in air, using the smaller cylinder, isothermally, with variable expansion ratio.
Here, we clearly have exp ratio > P_atm/P_final
We then compress the larger cylinder isothermally, this time
we have exp ratio = P_atm/P_final
Thus we have gained energy from the air, or so it seems?
This is because work of isothermal expansion is proportional to ln(exp ratio)
Any piston that compresses isothermally must do so at low speed. A practical reality of low speed operation is that mechanical friction losses and leakage losses become a larger percentage of the total work. There is a speed that minimizes both adiabatic losses and mechanical friction losses, for the best compression efficiency. At that speed, the compression cylinder is "large", thus expensive. The most economical compression design trades off adiabatic losses, friction losses, capital cost, and operating cost to get minimum net present operating cost.
For an example of the reverse situation, search Atkinson cycle engine. The Wikipedia hit is a good place to start.
Then study some thermodynamics until you understand that you are trying to invent, if not a perpetual motion machine, a cycle better than the Carnot cycle (search that term also).
Do all of that until you can discuss your cycle using the correct equations, and calculating the efficiency relative to both isothermal and adiabatic compression. Do this while recognizing that your design cannot do perfect isothermal or adiabatic compression. Include pressure - temperature - time curves for your cycle, isothermal compression, and adiabatic compression. Discuss the conditions necessary to get isothermal and adiabatic compression, with calculations.
If you spend sufficient time studying the above, show us your work and we can help you proceed further.
Likes phinds and berkeman
I do get net work with adiabatic compression, but only if the large cylinder is kept under environment temperature during the fill phase. If the heat is left to build up freely, negative work done.
It is relatively inefficient with 60L large cylinder and 1L small.
To make it efficient a gas container for keeping the inlet pressure high can be used, but it will have to be huge!
At one atmosphere its about 1.5KW with two alternating phase 1L small cylinders and one larger 60L one.
I guess it would need a 3-4 K drop in the large cylinder due to high volume (drop at the fill in phase), hopefully it still works then.
You still need to do this.
Then you have an energy flow that must be included in your calculations.
Wrong. See above for why it's wrong.
It seems that to get 10K drop in a 1L small cylinder it needs to have area of 6m^2.
About the large cylinder, to be able to do sufficient heat exchange area can be similar.
Note that "everything" is isothermal except the compression.
So it is outputting air hotter than the environment, while doing work.
But the heat is flowing in through a heat exchanger in the cylinders.
Technically that makes the efficiency negative even though its doing work since the heat is flowing from colder to hotter air.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
12K
16K
