Pure, proper mixed, and improper mixed states in laymen's terms
In summary, according to this poster, a quantum system can be in a pure state (where all variables are known and there is no uncertainty), a proper mixed state (where each system is in a different pure state but the result of an observation is still unknown), or an improper mixed state (where each system is in the same pure state but the result of an observation is known). In a pure state, one has many systems all prepared in the same pure state, and there is in principle, a measurement that when performed on each system will give exactly the same result. In a proper mixed state, each system is in a different pure state, so there is no measurement that will give exactly the same result when
batmanandjoker
75
This is how one poster tried to explain it to me but for people who have only taken a basic physics course in college it leaves a lot wanting.
"If a system is in a pure state, and you know what the pure state is, then your knowledge of the system is complete, and all uncertainty is quantum. If we take a state to apply to an ensemble, this means that every member of the ensemble has been identically prepared and is in the same state."
I interpret this as a controlled experiment in a lab where all values are accounted for and a photon is fired which has collapsed the particle. Here there is no uncertianty about actual collapse because the enviorment has been purposflley taken out of the equation yet collapse occurs.
"A proper mixed state means that you do not know exactly what the quantum state is, but only what the state is with some probability, so uncertainty is due to intrinsic quantum uncertainty, as well as your ignorance of the state. In an ensemble, this means that not all members of the ensemble have been identically prepared."
This is also conducted in a controlled lab where the enviorment has been taken out of the equation and a photon is not fired at the particle and superposition is apparent.
"An improper mixed state comes about when the entire system is in a pure state, but you restrict yourself to observing a subsystem. The improper mixed state describes the behaviour of the subsystem."
I assume the subsystem is the enviorment and when the enviorment is not isolated in a vacuum it acts like a pure state where superposition isn't present and the enviorment has apparently collapsed but since the enviorment has not been taken out of this equation in fact it is the core of an improper mixed state it is impossible to know if collapse has actually occurred because the variables are not controlled. It is assumed the enviorment has collapsed the system by interacting with itself but it is uncertian because the variables are not controlled.
Im sure I am wrong about a lot of this so that's why I am asking for help in figuring this out. Any help would be much aprecciated.
In a proper mixed state, each system is in a different pure state, so there is no measurement that will give exactly the same result when performed on each system.
In an improper mixed state, each system is in the same pure state, so there is in principle a measurement that when performed on each system will give exactly the same result. The improper mixed state is the state of a subsystem, and the uncertainty is due to different subsystems being entangled, and to performing a measurement on a subsystem rather than the whole system.
By system you mean the meusuring device is a system, the photon is a system and the particle is also a system. Is this correct. What is a system in this case.
What is a subsystem exactly and what is the whole system.
No I just mean the quantum system. If the quantum system has two spins, then each spin would be a subsystem. I consider the measuring apparatus classical.
Mate you have run into one of the problems of physics.
Some things require the full technical detail to explain, and that includes the entire mathematical machinery.
Using math its a doodle to explain those things - without it rather difficult.
Here is the mathematical explanation.
By definition a quantum state is a positive operator of unit trace. By definition a pure state is such an operator of the the form |u><u|. A mixed state is the convex sum of pure states ie ∑pi |bi><bi| where ∑pi =1. It can be shown all states are either pure or mixed. For filtering type observations (ie ones where the system is not destroyed by the observation) the outcome is a pure state and is in fact the so called collapse postulate - but that's a bit of a misnomer because it can be derived from other considerations such as physical continuity. If you observe a system whose state is already in one those possible outcomes then nothing happens, no collapse - nothing - QM is easy. One way to physically get a mixed state is to randomly present pure states to be observed, the pi representing the probability that state has been selected for observation. Suppose the |bi><bi| are the outcomes of your observation. For such a situation measurement problem solved - the state you observe is what's there prior to observation, nothing collapses or changes, and everything is sweet in quantum land. Such states are called proper mixed states. However what decoherence does is transform a superposition into a mixed state. Its mathematically and observationally exactly the same as a proper mixed state, but because it wasn't prepared the same way as a proper state so is called an improper state.
This is the crux and the essence of decoherence and the measurement problem. If it was a proper mixed state measurement problem solved. But it isn't - it wasn't prepared the same way. However its impossible to tell the difference. It APPARENTLY has solved the measurement problem - it hasn't really - but without any kind of contradiction you can assume it's a proper mixed state and collapse has already occurred. It hasn't, but it looks like it has, smells like it has, and in every way acts like it has. It is the basis of the ignorance ensemble interpretation I hold to.
That's the math. Explaining it without that I simply can't do. The jig is up - you need to study the math.
I recommend - Ballentine - Quantum Mechanics - A Modern Development.
Thanks
Bill
Likes batmanandjoker
so a pure state there is no collapse whereas mixed states do exhibt collapse. Is this correct.
No.
Pure states are the states you read about in the populist publications and beginning textbooks. They are the states the principle of superposition applies to and implies they form a vector space. But states are more general than that. First, strictly speaking they are not elements of a vector space - they are the projection operators formed from those elements ie if |u> is the state in the vector space sense the actual state is the operator |u><u|. This is also the reason why multiplying the state by a phase factor does nothing - it gives exactly the same operator.
However states are more general than this and also includes convex sums of such states ie operators of the form ∑pi |bi><bi|. These are the mixed states.
What decoherence does is transform a superposition into a mixed state, and that state LOOKS like collapse has occurred. Decoherence explains APPARENT collapse - not actual collapse.
I realize the above is probably gobbly-gook because you don't have the required physical and mathematical background.
However the jig is up here - I simply can't explain it any other way.
If you want to understand it you must learn the technical detail.
Thanks
Bill
ok thank you anways
Let's consider a system of one spin.
A pure state means that we have prepared many copies of the system of one spin, and each copy of the system is in the same pure state. For example, every copy of the single spin is pointing up.
A proper mixed state means that we have prepared many copies of the system of one spin, and each copy of the system is in a different pure state. For example, some copies of the single spin are pointing up and some are pointing down.
To illustrate an improper mixture, we have to consider a system of two spins. The system is in a pure state, which means we have many copies of the system of two spins, and each copy of the system of two spins is in the same pure state. If the pure state is one in which the two spins are entangled, then the state of a subsystem of one spin is an improper mixed state. We call the state of the subsystem a mixed state, because the subsystem in every copy behaves as if it is a proper mixed state. However, it is an improper mixed state, because if we consider the system of two spins, it is pure. So while we cannot distinguish between the proper and improper mixed state by looking at a subsystem of one spin, we can if we look at the entire system of two spins.
is this even possible to look at the whole system , is there evidence that it is infact noticbley diffrent when you look at the whole system or is this just a theory
In simple cases such as a system of two spins, it is possible to look at the whole system.
In complex cases, when the system includes a complex environment, it is just a theory. This practical inability to look at the whole system in such cases is why decoherence is said to be "apparent collapse".
In real collapse, the system evolves from a pure state to a proper mixed state.
In decoherence, the system consisting of environment + experiment is in a pure state and does not collapse. Here the experiment is a subsystem. Because we can only examine the experiment and not the whole system, the experiment through getting entangled with the environment will evolve from a pure state into an improper mixed state. Since the improper mixed state looks like a proper mixed state that results from collapse as long as we don't look at the whole system, decoherence is said to be apparent collapse.
so how do you explain the wolrd of classical physics I mean the real world if decoherance doesn't cause actual collapse why can't I walk through walls.
In textbook quantum mechanics with collapse, quantum mechanics does not explain the world of classical physics. When we do quantum mechanics, we always divide the universe into classical and quantum realms. Basically, you and your measuring apparatus are classical, and the measurement results you get when the apparatus probes a quantum system are also classical. Quantum mechanics assumes that a classical world exists, and provides a way to calculate the probabilties for various classical results that you measure. Collapse is what happens to the quantum system when the classical measuring apparatus interacts with the quantum system and you get a classical result.
There are interpretations without collapse, such as de Broglie-Bohm theory and many-worlds. You can look at those for an explanation of why the classical world exists. But the standard textbook interpretation with collapse doesn't explain the classical world, and assumes its existence.
Related to Pure, proper mixed, and improper mixed states in laymen's terms
1. What is the difference between pure, proper mixed, and improper mixed states?
Pure states refer to a state of a system in which the exact state is known, and there is no uncertainty. Proper mixed states refer to a state in which the system can be in one of multiple possible states, but the probabilities of each state are known. Improper mixed states refer to a state in which the system can be in one of multiple possible states, but the probabilities of each state are not known.
2. How do you determine if a state is pure, proper mixed, or improper mixed?
To determine the type of state, you need to know the exact state of the system and the probabilities associated with each state. If the state is known and there is no uncertainty, it is a pure state. If the state is not known, but the probabilities of each possible state are known, it is a proper mixed state. If the state is not known and the probabilities of each possible state are not known, it is an improper mixed state.
3. Can a pure state ever become a mixed state?
No, a pure state cannot become a mixed state. Once a state is known with certainty, it remains a pure state. However, a mixed state can become a pure state if the probabilities of each state are known and the system is measured to be in a specific state.
4. What is an example of a pure state?
A simple example of a pure state is a coin toss. When the coin is in the air, it is in a superposition state of heads and tails. However, once it lands and is observed, the true state is known and it becomes a pure state of either heads or tails.
5. Why is it important to understand pure, proper mixed, and improper mixed states?
Understanding these concepts is crucial in quantum mechanics and other areas of physics as they describe the behavior of particles and systems. They also play a vital role in quantum computing and understanding the properties of different materials. Additionally, understanding these states can help us make sense of the probabilistic nature of the quantum world and make predictions about the behavior of particles and systems.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
