Putting links in graphics?
  • Thread starter Thread starter BillTre
Inserting links into graphics for forum posts or articles can be challenging due to HTML limitations. The concept of an image map allows for specific areas of an image to be clickable, but most forums do not support this feature. The Insights editor may allow the use of image maps, unlike standard forum editors. Users seeking to link text within graphics should explore the capabilities of the Insights editor for potential solutions. Overall, while the functionality exists in HTML, its implementation in forums is often restricted.
BillTre
2024 Award
Is there an easy way to put links into graphics (vector drawings), such as for InSights articles of forum posts?
For example, if I have some text in a drawing, can I link it to an article somewhere, either from the text or on someway putting a transpartent button over it?
Links that are limited to specific areas of the image? That needs more html features than forums allow.
The feature you refer to exists in HTML and is called an image map ("map", see below). It allows an image to have clickable areas.
I don't know any fora that support it.
Code:
<img src="workplace.jpg" alt="Workplace" usemap="#workmap">
<map name="workmap">
  <area shape="rect" coords="34,44,270,350" alt="Computer" href="computer.htm">
  <area shape="rect" coords="290,172,333,250" alt="Phone" href="phone.htm">
  <area shape="circle" coords="337,300,44" alt="Coffee" href="coffee.htm">
</map>
I was afraid of that, but thought it worth checking.
Thanks guys!
Homework Statement: Not applicable. I'm asking about a technical problem with the PhysicsForums software Relevant Equations: \left(-2+2 \,\mathrm{I}\right)^{\frac{1}{3}} \left(-2+2 \,\mathrm{I}\right)^{\frac{1}{3}} I posted the LaTeX code for an expression in the "relevant equations" and "attempt at a solution" boxes. When I'm in the "attempt at a solution" box and I click "Preview," I do not see a preview of the expression properly displayed, only the code. After I post this message...
