Python Python-Confused in list comprehension-:
  • Thread starter Thread starter shivajikobardan
    List
The discussion centers on understanding list comprehension in Python, specifically how to find the difference between two lists. The example provided demonstrates how to remove elements from one list (list1) that are present in another list (list2) using list comprehension. The key line of code, "res = [i for i in list1 if i not in list2]," creates a new list (res) containing only the elements from list1 that are not found in list2. This is equivalent to a traditional for loop that checks each element of list1 against list2 and appends the non-matching elements to res. The explanation clarifies that the use of "if i not in list2" is crucial for achieving the desired outcome of filtering out elements. Additionally, there is a request for guidance on writing mathematical expressions using LaTeX on the forum. Overall, the discussion highlights the utility of list comprehension for concise and efficient list manipulation in Python.
shivajikobardan
I want to find difference between two list. I came across sth called list comprehension. I can't tell you how confused I am with this.
Code:
# Python 3 code to demonstrate
# to remove elements present in other list
# using list comprehension
# initializing list1
list1 = [1, 3, 4, 6, 7]
# initializing list2
list2 = [3, 6]
# printing list1
print("The list1 is : " + str(list1))
# printing list2
print("The list2 is : " + str(list2))
# using list comprehension to perform task
# printing result
print("The list after performing remove operation is : " + str(res))
My confusion lies here-:
Code:
What is happening here? I can't understand a single word. How to understand this please guide me.
Also can you guide a link to how to write latex in this site(how to write math? I am familiar with stackexchange mathjax can I use that here?)
Technology news on Phys.org
List comprehension takes some time to get used to but it's a very nice way to do a number of operations in one line and store the result as a new list.Let's simplify the comprehension slightly to piece together what is going on.
res = [i for i in list1]
This is the same as doing this: for i in list1: It just loops over list1 and i is the value of the current iteration. Ok now let's go back to the full example.
Code:
This is the same as doing this.
Code:
res = []
for i in list1:
    if i in list2:
        res.append(i)
The first version that uses list comprehension loops over list1 using i, then during each loop it checks "Is i in list2?" then it stores all of the results to another list which we call res.
But the original code said "if i NOT in list2" and your code says "i in list2".
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
