Python Python: Generating All Possible Combinations?
The discussion centers on generating all possible combinations of values from a dictionary where each key can have multiple associated values. A sample dictionary is provided, illustrating how keys map to lists of values. The goal is to create a 2D list containing every possible combination of these values, with the example indicating a total of 360 combinations based on the provided values.Participants suggest using Python's itertools module, specifically the combinations function, to achieve this task efficiently. Additionally, the technique of backtracking is recommended for those who prefer a more manual approach. A code snippet is shared that demonstrates a method for generating combinations using a while loop and index tracking, which iterates through the dictionary keys and their respective values to build the desired output. Overall, the discussion emphasizes the utility of built-in Python functions and algorithms for solving the problem of generating combinations from a dictionary.
tangodirt
Need a little help here, if anyone can offer any advice. The problem I have is this. I have a dictionary that contains keys, and their possible values. I need to generate every possible combination of key values where each key can take on one of the possible values.
For example, the dictionary might look something like:
Code:
Value Dictionary: {1: [[A], [B], [C]], 2: [[D], [E], [F], [G], [H]], 3: [[I], [J]], 4: [[K], [L], [M], [N]], 5: [[O], [P], [Q]]}
So, for the "1" key, the possible values it can assume are A, B, and C. For the "2" key, the possible values it can assume are D, E, F, G, and H. This continues for all keys, of undefined number of possible values. For this example, the number of possible combinations is something of the form: 3*5*2*4*3 = 360.
I need a way to output a 2D list containing every possible combination. So, the algorithm would output something like:
Code:
Combination List: [[A,D,I,K,O], [A,D,I,K,P], [A,D,I,K,Q], [A,D,I,L,O],...,[C,H,J,N,Q]]
Where the length of the combination list would be 360 and the width would be 5.
Does python have any built in way to do this, or will I have to come up with some logic to do this by hand? If I have to do it by hand, does anyone have any recommendations? I'm guessing recursion might be the best way to do this, but I'm not sure.
Technology news on Phys.org
Yes, it can be done with recursion, more particularly, using the technique of backtracking. I suggest you to learn it, it's a simple, yet powerful technique.
http://en.wikipedia.org/wiki/Backtracking
here was my valiant effort at it.
Code:
def patterns(dictionary):
   key = sorted(dictionary.keys())
   index = [0]*len(key)
   elements = {}
   next = 0
   while True:
      i = 0
      for value in key:
         if i == 0:
            elements[next] = dictionary[value][index[i]]
         else:
            elements[next] =elements[next][:] +dictionary[value][index[i]]
         i += 1
      i = 0
      index[i] += 1
      while index[i] >= len(dictionary[key[i]]):
         index[i] = 0
         i += 1
         if i >= len(index):
            break
         else:
            index[i] += 1
      if i >= len(index):
         break
      next += 1
   return elements
val = {1: [["A"], ["B"], ["C"]], 2: [["D"], ["E"], ["F"], ["G"], ["H"]], 3: [["I"], ["J"]], 4: [["K"], ["L"], ["M"], ["N"]], 5: [["O"], ["P"], ["Q"]]}
print patterns(val)
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
