Python Python: Semidefinite program with CVXPy 'Error parsing inputs'
  • Thread starter Thread starter Master1022
    Program Python
The error 'Error parsing inputs' in CVXPy is likely due to compatibility issues between the CVXPy package and the Python 3.7 environment in Google Colab. Users have found that the same code works correctly in a local Jupyter Notebook with Python 3.9, indicating that the problem may stem from version discrepancies. To resolve the issue, users are advised to check the version of CVXPy being used in Google Colab and consider updating their environment or switching to a local setup where the code functions as intended.
Master1022
TL;DR Summary
I am trying to run a semidefinite program in Python using CVXPy. I have gone to the documentation and the example code in there doesn't run in Google Colab for me and yields the error: 'Error parsing inputs'.
Hi,
Question:
Why is the error 'Error parsing inputs' in CVXPy occurring?
Context:
I am trying to solve a semidefinite program in CVXPy (using Google Colab). I went to the documentation (HERE) and I copied the example code into a cell. It doesn't work for some reason and I don't understand why. It is throwing the following message: 'Error parsing inputs'. Why is this happening?
Code:
[CODE lang="python" title="CVXPy Semidefinite Code Documentation Example"]# Import packages.
import cvxpy as cp
import numpy as np
# Generate a random SDP.
n = 3
p = 3
np.random.seed(1)
C = np.random.randn(n, n)
A = []
b = []
for i in range(p):
A.append(np.random.randn(n, n))
b.append(np.random.randn())
# Define and solve the CVXPY problem.
# Create a symmetric matrix variable.
X = cp.Variable((n,n), symmetric=True)
# The operator >> denotes matrix inequality.
constraints = [X >> 0]
constraints += [
cp.trace(A @ X) == b for i in range(p)
prob = cp.Problem(cp.Minimize(cp.trace(C @ X)),
constraints)
prob.solve()
# Print result.
print("The optimal value is", prob.value)
print("A solution X is")
print(X.value)[/CODE]Any help would be greatly appreciated
Technology news on Phys.org
This appears to be a compatibility problem with the cvxpy package and the Google Colab Python 3.7 environment. It works for me in a local Jupyter Notebook environment (Python 3.9).
Likes Master1022 and berkeman
Thanks for the reply @pbuk ! That's correct - when I used a version on my local machine via a conda environment, then it worked
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
