Q3.10: Power Calculation w/ Reduction Gear
The discussion revolves around a power calculation problem involving torque and angular velocity, specifically in the context of a reduction gear. The user struggles with calculating the second and third answers, seeking clarification on how to determine the torque involved. Participants suggest using the same formula for different parts of the problem and discuss the significance of the results, particularly regarding the need for gearbox cooling. The conversation highlights the importance of understanding the relationship between resisting torque and the torque provided by the turbine shaft. Overall, the thread emphasizes the application of fundamental equations in practical scenarios.
Suman_babai
: [/B]
Qstn no. 3.10 in the attached image.
[ Moderator note: Copy of relevant portion of attachment inserted to make it visible here]
: For power calculation, [/B]
Power = torque * angular velocity... Also, reduction gear is used to deliver lower outout speed at samd torque.
: [/B]
I hav tried the above equations and also correctly calculated the 1st ans(2nd attachment) but I can't calculate the 2nd and 3rd ans... I hv approached the second one but ans is not matching.. pls help... also please explain it.. as i am very weak in it...
Hello Suman, :welcome:
why not use the same expression for b) as you use for a) ? You have ##\tau## and you have ## \omega## !
Yes.. but.. what is the value uf torque here ?
Yes I know. But how can I get the torque? If it is the resisting torque of water, then where goes the torque given by the turbine shaft ? Or will it be the difference between the above mentioned torques ?
For want of better you could start with that assumption ...
That is a nice subject for part (c) :rolleyes:
Ok I get the 2nd prt... and also the 3rd prt... thnks a lot.. but what is the significance of the 3rd part?
It's a giveaway: subtract 14.235 from 15. Too easy ! But it shows the gearbox needs cooling :smile:
Yes I know the mathematical prt. I jst wanted to know to know its significance... thank you very very much.
