QM- A bit of manipulation of expectation values.
In summary, the conversation discusses the variance of an observable Qhat in a state with wavefunction psi and shows that it can be written as <Qhat2>-<Qhat>2. The equation is further simplified by recognizing that the expectation value of an expectation value is just the expectation value.
trv
73
The variance of an observable Qhat in a state with wavefunction psi is,
(delta Qhat)2=<(Qhat-<Qhat>)2>
Show that this can be written as,
(delta Qhat)2=<Qhat2>-<Qhat>2
As above.
(delta Qhat)2=<Qhat2-Qhat<Qhat>-<Qhat>Qhat+<Qhat>2>
L.H.S=<Qhat2-2Qhat<Qhat>+<Qhat>2>
Right, you've got it
[itex]\langle \hat{Q}^2 -2\hat{Q}\langle \hat{Q} \rangle +\langle \hat{Q} \rangle \rangle[/itex]
Now recognize that [itex]\langle X \rangle [/itex] is just a number (the expectation value) and thus the expectation value of an expectation value is just the expectation value (that's a mouth full) i.e. [itex]\langle \langle \hat{Q} \rangle \rangle = \langle \hat{Q} \rangle[/itex] and so on. Therefore you get:
[itex]\langle \hat{Q}^2 \rangle - 2 \langle \hat{Q} \rangle \langle \hat{Q} \rangle + \langle \hat{Q} \rangle ^2 [/itex]
and I assume you can take it from there
Yep that helps. Thanks Maverick.
FAQ: QM- A bit of manipulation of expectation values.
1. What is QM and how does it relate to expectation values?
QM stands for Quantum Mechanics, which is the branch of physics that studies the behavior of matter and energy at the atomic and subatomic level. Expectation values are mathematical quantities that represent the average value of an observable in a quantum system. QM uses expectation values to make predictions about the behavior of particles in a quantum system.
2. Can expectation values be manipulated in QM?
Yes, expectation values can be manipulated in QM. This is because expectation values are mathematical quantities that can be calculated using the principles of quantum mechanics. By applying mathematical operations, such as addition or multiplication, to expectation values, scientists can manipulate them to make predictions about the behavior of particles in a quantum system.
3. How are expectation values used in experiments and calculations in QM?
In experiments, scientists can measure the expectation values of different observables to obtain information about the properties of a quantum system. For example, the expectation value of position can be measured to determine the average location of a particle in a quantum system. In calculations, expectation values are used to make predictions about the behavior of particles in a quantum system, such as the likelihood of a particle having a certain energy or position.
4. What is the significance of manipulating expectation values in QM?
The manipulation of expectation values in QM is significant because it allows scientists to make predictions about the behavior of particles in a quantum system. This has practical applications in fields such as quantum computing and quantum cryptography, where understanding and manipulating expectation values is crucial for the development of new technologies.
5. Are there any limitations to the manipulation of expectation values in QM?
While expectation values can be manipulated in QM, there are limitations to this manipulation. For example, the Heisenberg uncertainty principle states that certain pairs of observables, such as position and momentum, cannot be measured simultaneously with precision. This means that there are limits to the accuracy of expectation values and the predictions that can be made using them.
