Quantization of vector field in the Coulomb gauge
diracologia
I have a technical question and at the time being I can't ask it to a professor. So, I'm here:
If I try to quantize the vector field in the Coulomb gauge (radiation gauge)
A_0(x)=0,\quad \vec\nabla\cdot\vec A=0.
by imposing the equal-time commutation relation
[A_i(x),E_j(y)]=-i\delta_{ij}\delta(\vec x-\vec y)
then I should find
\partial_i[A_i,E_j]=[\vec\nabla\cdot\vec A,E_j]=0,
since \vec\nabla\cdot\vec A=0, which is inconsistent with \partial_i\delta_{ij}\delta(\vec x-\vec y)\neq 0.
My question is simply how to take this divergence
I'm getting
\partial_i[A_i,E_j]=[\vec\nabla\cdot\vec A,E_j]+A_i\partial_i E_j-(\partial_i E_j)A_i .
I must be missing something in the math here. Can anyone help me?
I don't remember much of this, but if you can write \vec E=-\nabla\phi, then the last two terms cancel each other out.
then I should find
I'm getting
\partial^{x}_i[A_i(x),E_j(y)]=[\vec\nabla\cdot\vec A,E_j(y)]
you are not differentiating with respect to y. If you want to avoid confussion just set y = 0.
Sam
Kaku's QFT p.110 seems to be addressing your question:
"If we impose canonical commutation relations, we find a further complication.
[Ai(x,t), Ej(y,t)] = −iδijδ(x⃗ − y⃗)
However, this cannot be correct because we can take the divergence of both sides of the equation. The divergence of Ai is zero, so the left-hand side is zero, but the right hand side is not. As a result, we must modify the canonical commutation relations as follows:
where the right-hand side must be transverse; that is:
δij = ∫d3k/(2π)3 exp(ik·(x-x') (δij - kikj/k2)
[In other words, in Coulomb gauge only the transverse part is quantized, so only the transverse part appears in the commutator.]
EDIT: In other books they make this even more explicit by putting a "transverse part" operator on both A and E on the left hand side.
Thank you all,
Sam, you solve my puzzle. I just puted \partial_i and forgot that this is a differentiation only over x. Shame on me!
We often see discussions about what QM and QFT mean, but hardly anything on just how fundamental they are to much of physics. To rectify that, see the following; https://www.cambridge.org/engage/api-gateway/coe/assets/orp/resource/item/66a6a6005101a2ffa86cdd48/original/a-derivation-of-maxwell-s-equations-from-first-principles.pdf 'Somewhat magically, if one then applies local gauge invariance to the Dirac Lagrangian, a field appears, and from this field it is possible to derive Maxwell’s...
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
