A Quantum analog of Boltzmann entropy?
Demystifier
Insights Author
In classical statistical physics, entropy can be defined either as Boltzmann entropy or Gibbs entropy. In quantum statistical physics we have von Neumann entropy, which is a quantum analog of Gibbs entropy. Is there a quantum analog of Boltzmann entropy?
Likes jbergman, Fra and gentzen
I'd say the "Gibbs entropy", in connection with information theory also known as "Shannon entropy", in the context of information-theoretical applications in statistical physics as "Shannon-Jaynes entropy" and specifically in connection with QT as "von Neumann entropy", is the general concept, and boltzmann entropy the special application to the microcanonical ensemble in thermal equilibrium.
But Botzmann entropy can also be defined out of equilibrium. More importantly, out of equilibrium, Boltzmann and Gibbs entropy are different.
It depends what you understand under "Boltzmann entropy". I thought it's just for the microcanonical ensemble $$S=-k_{\text{B}} \ln \Omega,$$
where ##\Omega## is the dimension of the subspace with fixed additive conserved quantities, which is an equilibrium state.
The Shannen-Jaynes entropy,
$$S=-k_{\text{B}} \mathrm{Tr} (\hat{\rho} \ln \hat{\rho}),$$
is general, and applies to all kinds of states, ##\hat{\rho}##, be they equilibrium or off-equilibrium.
See the first paper in #4.
I see, but still with this definition the Boltzmann entropy is not the most general case. It uses only the one-particle distribution function, and the the H-theorem is derived from the Boltzmann equation, which already is "coarse grained" by "cutting" the BBGKY hierarchy by throwing away correlations, and that's where the increase of Boltzmann entropy comes from. Imho, the Gibbs entropy is the more general notion.
In this sense the "quantum analogy" of Boltzmann entropy is just given by "counting" a la Planck, Einstein, Fermi, and Dirac states in with single-particle occupation, neglecting two-particle and higher correlations, which leads to
$$S=\pm \frac{g}{(2 \pi \hbar)^3} \int_{\mathbb{R}^3} \int_{\mathbb{R}^3} \mathrm{d}^3 x \mathrm{d}^3 p [f \ln f \pm (1\pm f) \ln(1 \pm f)],$$
where the upper sign stands for bosons the lower for fermions.
For this the H-theorem follows for the BUU collision term (including Bose enhancement/Pauli blocking factors). For details, see Sect. 1.8 in
https://itp.uni-frankfurt.de/~hees/publ/kolkata.pdf
Likes mattt, jbergman and dextercioby
I don't know why do you say that. Before Eq. (1) it is said that the phase space of ##N## particles is considered. The Boltzmann entropy is defined in Eq. (2), where ##X## is the point in this phase space.
Yes, but then I read further, how the authors finally apply it.
Can you be more specific? Which page or equation applies it to one particle only?
Sec. 5.4. The title of the section is telling!
But this is just one example (as the title is telling). From one example it does not follow that they study only one-particle distributions. In most of the paper they study ##N##-particle phase space.
I have to read this book chapter in detail, but I don't see, why one should prefer a less general concept over a general one. Of course, you can extend the study of (semi-classical) transport including higher-order correlations. Sometimes that's even mandatory, e.g., when there are a long-ranged interactions like electromagnetic interactions (leading to the Vlasov-BUU equations). The most general approach, using the Schwinger-Keldysh formalism (which is the most convenient one; another is the quantum-Liouville approach) can be found here:
K. Chou, Z. Su, B. Hao and L. Yu, Equilibrium and
Nonequilibrium Formalisms made unified, Phys. Rept. 118, 1
(1985), https://doi.org/10.1016/0370-1573(85)90136-X
Likes dextercioby
Their argument is that, in classical physics, Boltzmann is better because Boltzmann entropy is a function of the actual position in the phase space, while Gibbs entropy is a functional of the probability distribution. This also explains why Gibbs entropy has a natural analog in quantum physics (because quantum physics is intrinsically about probability distributions), while it is not so obvious what is a quantum analog of Boltzmann entropy (because it's not clear what's the "actual" state in quantum physics). Indeed, their quantum Boltzmann entropy is clearly defined only in some interpretations, such as the Bohmian one.
They also point out that von Neumann (i.e. quantum Gibbs) entropy is unphysical in some cases. For example for a Schrodinger cat, which has equal probabilities of being dead (i.e. cold) and alive (i.e. warm), the von Neumann entropy is
$$S=\frac{1}{2}S_{\rm cold}+ \frac{1}{2}S_{\rm warm}$$
while the actual entropy is either ##S_{\rm cold}## or ##S_{\rm warm}##.
Of course, the conceptional difficulties of classical statistical mechanics are greater than in quantum statistical physics. Any only-classical theory of matter is conceptionally difficult, and I don't see the merit of developing an ab-initio classical statistical mechanics, when it can be derived much better from the appropriate approximations of quantum statistical mechanics, and there what's most natural indeed is the Shannon-Jaynes-von Neumann entropy as the starting point.
Their argument that for a closed system entropy is constant due to unitary time evolution in QT is also not convincing, because the same holds for Boltzmann entropy, when looking at a closed system due to Liouville's theorem, according to which phase-space volume is conserved.
Likes dextercioby
The Boltzmann entropy as they define it is not constant, because they don't define it as you think they do. They consider a single microscopic trajectory ##X(t)## in the phase space, not an ensemble of trajectories. At each time ##t## the state is a single point in the phase space, so its volume is zero and the Liouville's theorem is irrelevant. The finite phase-space volumes are introduced in a totally different way: they divide the whole phase space into finite cells, so that each cell corresponds to one possible mAcroscopic state. A possible mAcroscopic state becomes an actual mAcroscopic state when the microscopic ##X## actually arrives into that mAcroscopic cell. The actual mAcroscopic state is changed when the microscopic state ##X## arrives from one mAcroscopic cell to another. The Boltzmann entropy of macroscopic state is defined as (Boltzmann constant times the logarithm of) volume of the cell, so the entropy increases when the ##X## arrives from a smaller cell to a larger one. The size of ##X## is always the same (and is zero), but what changes is which cell is filled with ##X##.(*)
(*)A nice analogy is a car in the city. The size of the car is constant and negligible compared to the size of the city. But the car travels through the city, so often arrives from a smaller city district to a larger one.
Interesting question. I'll add my oddball perspective, although I've not sure if it's what you were after.
FWIW, I also find the boltzmann version more general if I most generally associates the possible complexions with the agents microstates - given it's inferred expectation defined as (in simplest possible case) for example historical frequencies of distinguishable events as received from the environment. So conceptually this is the "boundary" or communication channel ot other agents in the environment. The unknown microstate correspondens then to the HIDDEN microstate of the agent. (MAYBE this will take the role of your solipsist HV, even if our abstractions/interpretations are quite different?).
This is something one can toy around it, and it's a key idea also in my preferred interpretation. We know already there are many attempts to explain some interactions, as "entropic" in nature. For example Ted Jacobson's entropic gravity. Also Ariel Caticha has had such ambitions to derive the laws of physics and GR in particular from the rules of inference (entropic methods). But most of the attemps I am aware of have a fatal flaw, that somewhere (depending on the specific model) there are some arbitrary - hard to justify empirically - prior distributions or ergodic assumptions etc. I think these essentially become sa fine tuning problem conceptually. But what if one tries a similar thing, but uses agent/observer defined, measures? I find this quite interesting and promising. It gets more complicated, and objectionaly to some but is interesting.
To associate to Bohmian mechanics, one can ask, how can a theory about something hidden or unobsevable possible add explanatory power? I think the answer lies not from the ambigous choices, but what happens when ambigous choices are allowed to interact and spontaneous evolutionar selections maybe takes place? After all in quantum gravity we have the black hole information paradoxes, so something strange likely has to be going on anway. Can we expect a simple explanation to weird things?
/Fredrik
Edit: for some reason i assumed this was in interpretation subforum but now i see its not, i probably took the wrong spin on this.
Just look at the history of statistical mechanics. How can Boltzmann hypothesis that thermodynamics arises from motion of invisible atoms possibly add explanatory power? At that time (late 19th century) there was no direct evidence for the existence of atoms, and Mach indeed argued that Boltzmann statistical mechanics based on assumption of atoms was a nonsense. It was Einstein in early 20th century (1905) who finally convinced physicists that atoms actually exist, by explaining the Brownian motion from the assumption of atoms.
Likes dextercioby, vanhees71 and Fra
Initially, I was mainly interested in a technical and practical definition of quantum Boltzmann entropy. But of course, the question also evokes some foundational issues.
I lost track of what you referenced to, which paper did this come from.
It also sounds closer to what may make sense for an agent view; where in the simplest of cases one can consider that the angent can hold say a string of inputs at any given time. Loosely speaking we can call it X(t) except t would likely be discrete. From this, internal processing can take place and the agent can compute from the one data it has, expectations of future strings or substrings, and assign macrostates as "relative frequences". This way allows a rational way for the statistics witohut ensembles, the effective scores can be defined with the one data set in X(i) - the observers memory essentially. This is how I picture the basal starting points of agents microstates. I was curious to see if this is more than a conincidence.
So which paper did you get this from?
/Fredrik
The first one in #4.
I find this is a lot of talk but no clear exposition of what the authors criticize about the standard definition of entropy a la Shannon, Jaynes, and von Neumann. That the H-theorem holds for closed systems only when a macroscopic coarse-grained description is used, follows from this more general concept of entropy. If you keep full information about the state of the closed system, its time evolution is described by unitary time evolution and thus entropy is conserved. If you refer to the time evolution of an open system, usually you get the H-theorem, i.e., that the corresponding entropy increases, and equilibrium is thus characterized by maximum entropy (under the given constraints about additive conserved quantities).
vanhees71 said:
I find this is a lot of talk but no clear exposition of what the authors criticize about the standard definition of entropy a la von Shannon, Jaynes, and von Neumann.
Did vanhees71 just promote Claude Shannon from commoner to German nobleman? :wink:
Of the three said scientists, only von Neuman was a (Hungarian) noble man.
Many interesting problems are raised and not unexpectedly the questions of which is the best IMO is rooted again in the interpreration of probability. After all, entropy is conceptually a way to make the factorization of statistical independence, instead additive, and sometimes to quantity how much memory is required to encode information etc. But to understnad the details, I find that one is led back to the foundations and interpretation of probability, and when it comes to these things I don't share the authors apparent critique against the "subjective entropy" interpretation. In chapter for they raise some valid issues with this, such as cases of "wrong entropy", or the lack of explanatory value as the premise appears abitrary dependng on the choice of obsevers.
From my perspective, the problems they raise must be taken seriously, but I see that they are potentially conceptually solved by a factor that they miss - the choice of observer is not completely arbitrary, because while any observer is "allowed", an observer that is flat out and grossly wrong, are not likely to be stable. This idea is completely LOST when one considers a fixed macroscopic background, which is the standard way. So I think the root of this entropy issue, is pretty much the same as other fountational questions on QM like the observer problem.
/Fredrik
You wrote "von Shannon" in #22.
Thanks, I corrected it :-).
Likes Demystifier
Note that the authors are Bohmians, so they have a very different mindset than a typical practical physicist like you, which explains why you have difficulties with understanding their point. It's not about different interpretations of QM (most of the paper is about classical statistical mechanics, anyway), but about general way of thinking in physics. You mainly ask practical epistemic questions, while they ask foundational ontological questions. From their point of view, the most important quantity is the exact position and momentum of every particle, in a system of large number ##N## (typically, ##N\sim 10^{23}##) of particles, and everything else should be defined in terms of this. From your point of view, even though you will accept that in classical physics one can talk about exact positions and momenta in principle, it does not make much sense in practice when ##N## is so big. That's why you find the Gibbs point of view much more natural and can't easily understand why they prefer the Boltzmann point of view. Loosely speaking, Boltzmann entropy is better suited for foundational ontological questions, while Gibbs entropy is better suited for practical epistemic questions. And sometimes physicists (including me) are not certain whether a question is foundational or practical, which is a part of the reason why they often get confused by different notions of entropy.
And of course, the Boltzmann vs Gibbs is not the only dilemma that causes a confusion. There is also the fine grained vs coarse grained dilemma; the frequentist vs Bayesian probability dilemma; the choice of ensemble (microcanonical, canonical, grand-canonical, etc.) problem; the real vs imagined ensemble; the difference between notions of ensemble, probability and typicality; the ##N##-particle phase space vs 1-particle phase space; the number of particles in the system vs the number of systems in the ensemble; the equilibrium vs non-equilibrium dilemma; the open vs closed system dilemma; and last but not least, the classical vs quantum statistical physics. There are so many levels at which someone can get confused in statistical mechanics.
Likes Fra and vanhees71
That explains a lot. Bohmians tend to preach their gospel... It's clear that within QT exact phase-space points don't make sense and that description of the state become useful when coarse-graining over phase-space cells much larger than ##\hbar^{2N}## is a sufficient description, i.e., if there's a separation of microscopic and macroscopic scales, and you are interested only in the macroscopic coarse-grained observables.
At least the applicability of the standard ensembles is pretty clear. If you have rather small systems, you need the microcanonical ensemble. If you have large energies but not so much (net) conseved charge you need the canonical and otherwise the grand-canonical ensemble. It depends on, whether the fluctuations of the macroscopic quantities of interest are large compared to the mean values or not, which ensemble is the better choice.
I think both ways are complementary and there is no need for conflict. I think the tension arises only because the "observer" is not taken as the active particpant and part of physical reality that is obviously is. In fact I see the agent perspective as aiming to unify this in that the ontology is motivated epistemologically via inference, and simultaneously the set of all "possible inferences" are constrained by the ontology, so both parts evolve in interaction.
/Fredrik
  • #31
It depends on what you mean by "observer". If you mean a human being, taking note of measurement results, it's most probably irrelevant. What you have to take into account sometimes is of course the interaction between the measured object and the measurement device.
  • #32
By observer do not mean humans, which I think I declared many times. It's thinking it's "humans" that are the root of the confusion.
I mean the observer=agent = the part of the universe in which the inference of the remainder takes place - ie the part that distinguishes, counts and records events at the input that interface to the rest of the world.
In your example, when considering QM or QFT in colliders etc (not talking about unification of gravity) the "observer" is IMO, ALL the macroscopic environment! This is essentially also as I see it what Bohr meant. Ie. the set of all possible classical pointers etc or what you call it. Or if we talk about special relatiivity, then the obvious generalisation is that the "observable" become the above modulo the poincare transformations. Ie the classical environment forms an equivalence class. The whole lab, including all also all it's computational power! But this is also why THIS observer is a fiction, because it's an asymptotic "superobserver". This is exactly why we do not consider THIS "observer" as part of the interaction beyond the idealised preparattion-detection.
The generealisation of this is what I look for, but the normal notion of above "observer" will be recovered when the "agent" becomes dominant. The generalization I think is they key to make progress on the open isuses (unification without finetuning, and QG). When you also try to do this generalisation both the ontology and the epistemolgoy is important. Both "extremes" are otherwise missing something.
/Fredrik
  • #33
Why don't you simply talk it measurement device?
Likes Demystifier
  • #34
Because then people tend to think of something described from ther perspective of another measurement device. Ie. If you think the "detector" is the measurement device, this detector is still described from the rest of the macroscopic world, meaning there is another measurement device further out.
I think the distinction is that the agent is supposed to be described from the inside, which makes it a bit subjective. But the objectibvity is supposedly restored - along with more explanatory power - when one ponders how these interacting agents change as they communicate. Ie. we expect there to be for example at a set of agents or "observers" that are related via a symmetry transformation. But WHICH symmetry transformation? I think there is more explanations begind WHICH symmetries that are manifested in nature.
Then we have no grip of this if we describe the measurement device in the external traditional way, becauase there is an implicit choice of background that causes problems and finetuning questions.
/Fredrik
  • #35
Detectors are usually all there is relevant in the sense of measuring a particle. They are indeed big enough to be treated classically. There is nothing more subjective in the quantum description of Nature than in the classical description. The question, which symmetries (or regularities, describable by mathematics) are manifested in Nature has to be found out by observation and model building in close interdepency. It's at the deepest level what the entire endeavor of the natural sciences is about.
  • #36
Yes, I agree. And the subjectivity of the macroscopic domain is neglectable when it comes to small subsystems.
But problems appear when the "quantum part" contains parts that are treated both as quantum, and as part of the classical part (ie. part of the observer). And even worse when one considers gravity.
The problem I see is this: Unless we find a more coherent theory that connects or relates the effective theories (much better than today that is), then - in principle - the scientific findings and the inference for any given experimental setup, has to be done independently for each observation or energy scale. This is not "wrong" but it leaves us with a patchwork of effective theories, with a bunch of experimentally tuned parameters, without the slightest clue how they are related.
Can we improve this situation? How?
/Fredrik
  • #38
Can a dog be an agent?
  • Haha
Likes dextercioby
  • #39
What I meant is that I that a agent/observer doesn't need to be human - not that can't be human, or a dog for that matter. I only want to get away from those associating "epistemology" as a human phenomena.
The generalized physical concept I imagine is more how one part of the universe can "learn" via interactions, about other parts of the universe. The parts does not need to have brains. As I see it, an agent needs at least a structure for encoding information, and a way to process this information and respond to input. This processing in my vision does not imply brains, or computers, it can be "natural processes". Ultimaltey, the instruction set would somehow be related to the laws of physics, but at the same time these laws are subject to constant evolution.
So, sure a dog can be an agent, or a a molecule can also be an agent in the general sense. In the ordinary sense of observer a la Bohr, where it's essential the macroscopic(or "classical") environment that is the observer, then the role of the human is that it can _control_ the laboratory and the procedure of preparation and detectors, electronics etc. In this sense the physicist at least in principle have control, and access to the whole macroscopic environment, at least to the extent technology and economy allows. The exeprimental uncertainty there is, is IMO a manifestation of the ambigousness of the macroscopic observer still. This uncertainty would be larger if the negineers at LHC were dogs, but the principles are the same.
Surely a dog can't do this, and dogs would not produce QED or QCD. Those "theories" are certainly human inventions.
So what I entertain at this point are "toy models" of primordal observers, which is like the simplest possible "agents" one can imagine. It's nowhere near a dog or a molecule in complexity, it's imaginary things that I envision would perhaps been dominating in some TOE era in early big bang. One idea is similar to string theory, where my "interpretation" of string theory, would be this: the "string" is the mathematical description of a primordal observer or a living "measure". The modes of the string represents it's way of encoding information. But the problem is that the strings also lives in a background spacetime, whose dynamics is poorly understood still it seems. The various dualities in string theory in my mind, corresponds to agents different "internal recodings" or alternative representations, which also gives different dynamics. But one would need to understand the interaction between strings, and systems of strings, to understand how the background is selected. Then one can imagine largers objects constructed by strings interacting and consider the evolutionary pressure of making transition to other bakgrounds (via dualities). But I have realise this is not how string theorists think, i can't recall ahving seen one paper in this direction. So I have chosen another path.
/Fredrik
  • #40
So, I'm hesitant to post this because I get a somewhat crack potty feeling to the book (however, he actually does reference some of your papers in the more "normal" section [i.e section 1.5.2 he references https://arxiv.org/abs/quant-ph/0305131]), but I'm not sure if that's because my Bohmian mechanics principles are weak (I only know the basic of how they apply the Hamilton-Jacobi equations), but with that being said...
I stumbled upon this book https://www.amazon.com/dp/9813227974/?tag=pfamazon01-20 in my search for a book to learn this theory.
At the start of chapter 2, he states:
"##S_Q=-\frac{1}{2} \ln \rho##
where ##\rho## is the probability density (describing the space-temporal distribution of an ensemble of particles, namely the density of particles in the element of volume ##d^3 x## around a point ##\vec{x}## at time ##t## )associated with the wave function ##\psi(\vec{x}, t)## of an individual physical system. In the entropic version of Bohmian quantum mechanics, the space-temporal distribution of the ensemble of particles describing the individual physical system under consideration is assumed to generate a modification, a sort of deformation of the background space characterized by the quantity given by equation (2.1). On the basis of equation (2.1), it is plausible to make a parallelism with the standard definition of entropy given by the Boltzmann law, in other words equation (2.1) may be considered indeed as the quantum counterpart of a Boltzmann-type law. In the light of its relation with the wave function, the quantity given by equation (2.1) can be appropriately defined as "quantum entropy". The quantum entropy (2.1) can be interpreted as the physical parameter that, in the quantum domain, measures the degree of order and chaos of the vacuum - a storage of virtual trajectories supplying optimal ones for particle movement - which supports the density ##\rho## describing the space-temporal distribution of the ensemble of particles associated with the wave function under consideration."
So, the issues I have is that everything he references in this part is... his own articles, which IMO isn't THAT big of an issue, it just gets more suspicious because I can't find the journals/papers. But, I'll post this for you, and let you be the judge.
[BTW, in case anyone is interested, I ended up going with https://www.amazon.com/dp/0521485436/?tag=pfamazon01-20 but just need to actual take time and study the chapters in depth, but it is a nicely written book so far IMO.]
Likes dextercioby
  • #41
@romsofia Holland is a classic, pretty sure anyone working in BM read it. While for the 1st book you quoted, you need to check the table of references (bibliography). Does it contain only known books and articles in peer-reviewed journals? Does it include references published by the book's author? Making sure of these does not, however, exclude the possibility that the book is full of crackpot ideas, or simply wrong statements. Today, anyone can publish a book. WS, Springer, and others will not ensure that the board of editors accepts only correct manuscripts.
Likes Demystifier
  • #42
dextercioby said:
Does it contain onltly known books and articles in the peer-reviewed journals? Does it include references published by the book's author?
Exactly the issue I ran into. One of his own papers (that he references a lot to justify the relation in the boltzmann entropy) comes from "D. Fiscaletti, “Perspectives of Bohm’s quantum potential towards a geometrodynamic interpretation of quantum physics. A critical survey”, Reviews in Theoretical Science 1, 2, 103–144 (2013)". However, this journal seems to be gone (and predatory?).
In fact, the only reason I decided to go ahead and post is because the book's author heavily uses OP's work, and even goes as far to dub his work as "Nikolic's approach" throughout the book. So, if anyone could be a proper judge, I'd guess it'd be from somehow who wrote the papers that influenced a lot of this book.
Likes Demystifier
  • #43
Sorry, for me publishing in a predatory journal is akin to uploading to vixra, because you can't get an endorsement to upload it to arxiv. @Demystifier Is this book by a certain Fiscaletti author known to you? Care to make some comments on it? Thanks!
Likes vanhees71 and Demystifier
  • #44
It refers to my older works, but my approach has significantly changed in the meantime. My current view of Bohmian mechanics is best represented by the article in my signature, and more recently by https://arxiv.org/abs/2205.05986 where the last section describes how my views changed over time.
Likes vanhees71 and romsofia
