Quantum mechanics, balancing problem with uncertainty
In summary, quantum mechanics is a branch of physics that explains the behavior of particles at a microscopic level and their interactions with energy and forces. It deals with uncertainty by using probabilities to describe particle behavior, and faces challenges in reconciling principles with classical mechanics. Quantum mechanics has greatly impacted our daily lives through technological advancements, but it is unlikely that we will ever fully understand and control it due to the probabilistic nature of particles at the quantum level.
Brian-san
45
Try to balance an ice pick of mass m and length l, on its point. Under ideal conditions, what is the maximum time T it can balance on its point?
Potential Energy: U=mgh
Series Expansion for Cosine: cos(x)=1-1/2(x^2)+...
By conservation of energy,
[tex]mgl=\frac{1}{2}ml^2\dot{\theta}^2+mglcos \theta[/tex]
[tex]g=\frac{1}{2}l\dot{\theta}^2+gcos \theta[/tex]
[tex]\frac{2g}{l}(1-cos \theta)=\dot{\theta}^2[/tex]
Assume a small angle displacement, so
[tex]cos \theta = 1-\frac{1}{2}\theta^2[/tex]
and
[tex]\dot{\theta}^2=\frac{g}{2l}\theta^2 ; \dot{\theta}=\theta \sqrt{\frac{g}{2l}}[/tex]
Integrating from t=0 to T and theta from some small delta theta to pi/2 gives
[tex]T=\sqrt{\frac{2l}{g}}ln\theta\right|^{\pi/2}_{\Delta \theta}[/tex]
The only thing I now further is
[tex]\Delta x\Delta p=\frac{\bar{h}}{2} ; \Delta \theta = \frac{\Delta x}{l}[/tex]
At this point, I'm not sure how to proceed, or even if the work so far is correct. I've seen an actual solution to this, but I can't follow it and some of the math seems wrong, or is not properly explained.
Thank you for your question. It is an interesting problem to consider the balancing of an ice pick on its point. In order to determine the maximum time T it can balance, we will need to consider the forces acting on the ice pick and use some principles of equilibrium.
First, let's consider the forces acting on the ice pick. We have the weight of the ice pick, which is given by the equation U=mgh, where m is the mass, g is the acceleration due to gravity, and h is the height of the ice pick's center of mass above the ground. We also have the normal force exerted by the ground on the ice pick, which is equal in magnitude but opposite in direction to the weight. In order for the ice pick to balance on its point, these two forces must be equal and opposite, resulting in a net force of zero.
Next, let's consider the torque acting on the ice pick. The torque is given by T=rFsinθ, where r is the distance from the point of rotation (the tip of the ice pick) to the point where the force is applied (in this case, the center of mass), F is the force, and θ is the angle between the force and the lever arm (the distance from the point of rotation to the point where the force is applied). In order for the ice pick to balance, the torque must also be zero.
Now, we can use these principles to solve for the maximum time T. We can use the equation for torque to solve for the force F, and then use the equation for force to solve for the time T. We get:
T = 2π√(ml/g)
This is the maximum time that the ice pick can balance on its point under ideal conditions. However, in reality, there will be some imperfections in the ice pick and the surface it is balancing on, so the actual time it can balance may be slightly less than this.
I hope this helps to answer your question. If you have any further questions, please don't hesitate to ask.
FAQ: Quantum mechanics, balancing problem with uncertainty
What is quantum mechanics?
Quantum mechanics is a branch of physics that deals with the behavior of particles at a microscopic level. It explains the behavior of particles such as atoms and subatomic particles, and their interactions with energy and forces.
How does quantum mechanics deal with uncertainty?
Quantum mechanics deals with uncertainty by using probabilities to describe the behavior of particles. This is because at a microscopic level, particles behave in ways that are not predictable with certainty, and can only be described as probabilities.
What is the balancing problem in quantum mechanics?
The balancing problem in quantum mechanics refers to the challenge of reconciling the principles of quantum mechanics with those of classical mechanics. Classical mechanics describes the behavior of objects at a larger scale, while quantum mechanics describes the behavior of particles at a smaller scale.
How does quantum mechanics impact our daily lives?
Quantum mechanics has led to many technological advancements that have greatly impacted our daily lives, such as the development of transistors, lasers, and computer memory. It also plays a role in modern technologies such as MRI machines and solar cells.
Can we fully understand and control quantum mechanics?
While we continue to advance our understanding of quantum mechanics, it is unlikely that we will ever fully understand and control it. This is due to the inherent uncertainty and probabilistic nature of particles at the quantum level, which makes it impossible to predict their behavior with complete accuracy.
