- #211
- 8,938
- 2,946
DevilsAvocado said:In the case of the double-slit, we can be certain that knowledge of which slit will destroy interference.
That sounds like a "wave function collapse" interpretation. I don't think it's unambiguously true that knowledge destroys the interference. What you can say is that the normal ways that one might attempt to detect which slit the particle goes through destroys the inference. That's because setting up such a detector changes the complete situation. (From the point of view of dBB, each electron is influenced nonlocally by the complete setup, not just the facts about what's happening along its own path).
Einstein was very skeptical about CFD, and maybe we are paying too much attention to this regarding EPR-Bell, I don’t know...
CFD as in contrafactual definitess? I'm not sure I understand the relevance.
As you are saying, it only becomes a problem when we perform the measurement, i.e. suppose Bell required us to have a 'particle' with 6 incompatible values. Then we could build a model of a real spinning 'dice', that for some (unknown) reason will never let us see these 6 values simultaneously, and when we perform a measurement, we will only get one value, based solely on classical probabilities.
What's the problem!?
The problem is that this model works very fine for the 1935 version of EPR, where we theoretically could utilize a 'common influence' on the two 'twin dices', showing correlated behavior at measurement, i.e. if one shows even numbers, the other always shows odd, and vice versa.
This however is a dead parrot after 1964 and Bell's theorem, which mathematically proves that to have 'real twin dices' spinning at the source, the 'common influence' is not 'strong' enough to explain what happens in QM experiments (and predictions).
Bell's theorem has an essential step, which is the assumption that whatever hidden variables there are have an associated measure, or probability. I don't completely know what the physical meaning of nonmeasurable hidden variables would be, but it certainly is a necessary assumption for Bell's proof to go through.
