I Quantum numbers - Total Energy and Orbital Momentum
klw289
With the quantum numbers l=1, n=2 and m=-1 how do I calculate the total energy E, L2 (the square of the orbital momentum) and Lz (the z-component of the orbital angular momentum.
I've been trying for two hours and am getting no were. Please help
Is this a homework problem? If so, it should be moved to the homework section, and should be put in the proper homework problem format.
Likes secur
This was not "homework" I am just reading a physics book for my own enjoyment and I was reading a section and I have no clue how to get started. I could post it in homework if its more suitable?
Well, the actual way that these things are figured out is to start with Schrodinger's equation. That's a pretty complicated undertaking, which can't really be described in a post. If you just want to skip to the answers: For a hydrogen atom,
E = \frac{- m q^4}{\hbar^2 n^2}
where m is the mass of an electron, q is the charge of an electron (in CSU units), n is the principal quantum number, and \hbar is Planck's constant.
L = \sqrt{l(l+1)} \hbar
L_z = m \hbar
For an atom other than a hydrogen atom, replace q^4 by N^2q^4, where N is the number of protons in the atom.
We consider this to be a "homework-like" problem. If your trouble is that you can't find the appropriate formulas, try here:
http://hyperphysics.phy-astr.gsu.edu/hbase/qunoh.html
Follow the links for "Principal quantum number", etc.
If you have the formulas but you can't get the numbers to come out right, go to the Introductory Physics Homework forum:
https://www.physicsforums.com/forums/introductory-physics-homework.153/
Post what you've done (show your work), and someone can probably find your mistake.
(stevendaryl slipped in ahead of me)
Thank you, that can get me started. I'll also go back to schrodingers equation.
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
