- #176
.Scott
- 3,485
- 1,599
<Moderator's note: Merged into this thread.>
With my limited understanding and practice with QM, I am tackling an article published in "Nature Communications" this past September regarding an analysis of a particular QM system.
Here is a link to that article:
https://www.nature.com/articles/s41467-018-05739-8
If you haven't read the article, the gist is that the result of a coin toss that favors tails drives the generation of a particle that is either |down> (for heads) or |up+down> (for tails). Given different QM calculations made from different sets of information, sometimes the original result of the coin toss can be demonstrated to be definitely heads and definitely tails at the same time. The point is that certain other basic, well-accepted assumptions are made and one of those has to be abandoned.
I have not finished my rereading/rerereading of this article, but I believe I see a problem right away - and I would like comments.
The problem I have is that the coin toss is being viewed as a QM event - but I don't think that it is being treated correctly. Basically, if you start with (##\frac{1}{3}##|heads> + ##\frac{2}{3}##|tails>), as a model for a coin toss, then the very first thing you need to do is to take that state and copy it so that agent ##\bar{F}## will remember it. In fact, the notion of a coin toss is that the coin is sitting there for anyone to observe - available for arbitrary copying.
But agent ##F## isn't considering this "copy" operation in her calculations.
So here is my question:
When working with QM states (in the way that is done in this experiment), don't you need to consider when a state is "copied"? In the case of this coin toss, I don't believe there ever is a quantum state (##\frac{1}{3}##|heads> + ##\frac{2}{3}##|tails>). Instead, there are other quantum states that resolve to a ##\frac{1}{3}## : ##\frac{2}{3}## ratio of a larger system (the coin). So if someone wants to consider the entire coin-toss/particle emission operation as a QM system, they would need to go back to QM conditions that led to the coin toss result.
