Question about 12v Solar charger?
In summary: Well, I don't know, really. It sounds like you may need to consult an electrical engineer about this.In summary, increasing the voltage to a maximum of 14V will boost the current and charge the battery more quickly.
beany_bot
Hi, I recently bought a smallish 12v DC solar panel for trickle charging my jetski battery. I've had a look at the panel with a multimeter and in good sunlight it makes easy 24V but very very low current. I was wondering if I stick a 99pence buck converter on in, forcing the voltage to a max of 14V. will this increase the current and in turn charge the battery quicker/better?
Don't know too much about these things so came here to ask the experts. Just I had a thought pop into my head that if I reduce the voltage I would get more current and charge the battery more? Is this the case?
I'm not an expert but I would try to do an aswer.
First, the convertion from radiant energy to electrical one is function of the efficience factor which is not equal to one, and this limits the maximum of obtained power by the solar device.
Second, if this device has a power P, say for example 2.4 watt, that is P = VI = 24 x 0.1, then the current converter get in input this power and it can't amplify it, because it must keep constant.
So since P = VI and V= 12 for example in the second device, the current must be about 0.2 A, that is the current is double.
But this in the case that the efficience of the current converter is 1.
Thank you for your reply and forgive my ignorance. So I'm right in thinking, by halving the voltage I'm doubling the current? Now, would this be better at charging the battery? Or because "P" is still "P" will it not make a difference? Thanks.
Hi beany_bot. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
In principle, the idea sounds feasible. Does the panel's documentation indicate its rated current output?
It doesn't state the current output, it "claims" 1.5W but as we know it will be very variable depending on sunlight. This is it http://www.amazon.com/dp/B000R0UBT8/?tag=pfamazon01-20
The amps are very very low, just a trickle charge. Basically wondering if increasing the amperage with lower voltage will charge faster or because the power is the same it won't make a difference.
Look at some data sheets, see whether you can find an efficient buck converter that demands low current for itself. You may be able to boost the current capability so the battery charges a bit faster.
I was just looking at this guy http://www.ebay.co.uk/itm/1PCS-Output-1-25V-35V-DC-DC-Buck-Converter-Step-Down-Module-LM2596-Power-Supply-/271528251706?pt=LH_DefaultDomain_3&hash=item3f3858513a
How did you measure the current? Shouldn't the voltage and current come into equilibrium depending on the load?
I haven't measured the current. I just assumed it is very low because...well, its a small solar panel operating in Scotland on a cloudy day lol.
A won't lie, a lot of this is going over my head, (I don't really have much knowledge about electrical physics).
Was just essential wondering if more amps / less volts will charge the battery better. And indeed will a buck converter do just that? will decreasing the voltage increase the amps? I was led to believe it will. Alas, doesn't more amps less volts just mean its getting more current, but slower, making the overall "energy" delivered to the battery in any given time frame the same? Argh my head hurts...
Well, I'm a mechanical engineer, not an electrical engineer, so I'll want someone else to verify, but typically the open circuit voltage isn't the real operating voltage on an unregulated source like a solar cell or battery. It naturally finds its own equilibrium with the circuit. If it is rated for 12V but produces 24V open circuit and you hook it up to a 12V battery (13.xV?) I'm pretty sure it will charge the battery at around 14V.
I'd just try it and see.
The more I think about it, the more I think about Einsteins conservation of energy law. I think the energy is going to be the same, no matter what I do. Doesn't matter if I give "x" amps at "x" volts or "y" amps at "y" volts. The energy I am putting into the battery will be the same. So Einstein says.
That is by no means a general principle. It only works if the Power remains the same and there is no reason to suspect that it applies when a non-linear device like a solar cell is involved.
There will always be an optimum condition for running a PV charger and you can buy devices (MPPT) that will try to get the best Power transfer into a load under all lighting conditions. For a small installation, the cheaper solution is just to use more area of cells - and the cheaper MPPT units are pretty poor, I've heard.
Sopiecentaur had the right answer. But if your panels are small enough, you do not need the expense. Charge controllers extract maximum energy, but their primary purpose is to prevent damage to the battery by overcharging.
If the charging current is 1 amp or less, it is considered a trickle charge. You can charge at that rate forever without damaging the battery. (You can stretch that to 1.5 or 2 amps). Just connect the panel to the battery directly, and don't worry.
If the current is in the range 2-7 amps, then an inexpensive pulse width modulator controller is best. They simply limit current to prevent battery voltage from ever exceeding 13.8 volts. Find some here.
For currents higher than 7 amps, buy a charge controller big enough for your needs.
The most expensive MPPT controlers not only protect, but optimize. But the biggest gains are with large installations and with voltages 48v or higher. For smaller or lower voltage applications, the extra expense of MPPT is not justified.
Bottom line, read the nameplate on your panel. Divide the watt rating by 13 to get currrent.
FAQ: Question about 12v Solar charger?
1. How does a 12v solar charger work?
A 12v solar charger works by converting the energy from sunlight into electricity. The solar panels on the charger contain photovoltaic cells, which absorb the sunlight and generate a direct current (DC) of electricity. This DC electricity is then converted into a usable form through a charge controller and can be stored in a battery or used directly to power devices.
2. Can a 12v solar charger be used for all types of devices?
Yes, a 12v solar charger can be used for a wide range of devices, as long as they are compatible with the voltage and current output of the charger. However, it is important to note that a 12v solar charger is best suited for smaller devices and may not be able to power larger appliances.
3. How long does it take to fully charge a device using a 12v solar charger?
The time it takes to fully charge a device using a 12v solar charger depends on various factors such as the size of the solar panel, the amount of sunlight available, and the capacity of the device's battery. On average, it can take anywhere from 2-10 hours to fully charge a device using a 12v solar charger.
4. Is a 12v solar charger suitable for outdoor use?
Yes, a 12v solar charger is perfect for outdoor use as it does not require a power outlet and can be used in remote locations. It is also lightweight and portable, making it convenient for camping, hiking, and other outdoor activities.
5. Can a 12v solar charger be used in cloudy weather?
While a 12v solar charger works best in direct sunlight, it can still function in cloudy weather. However, the charging time may be longer as the panels will not receive as much sunlight. It is recommended to use a larger solar panel or have a backup power source for prolonged use in cloudy weather.
14K
