elias001
- 389
- 30
- TL;DR Summary
- I have questions about the paper: "A Group Epimorphism is Surjective".
The following is from the paper "A Group Epimorphism is Surjective" by C.E. Linderholm
Background
Note: where it says the function from ##A/H## to ##A/H##, should it not be ##H/A## to ##H/A?##
Questions
There are some points about the above proof I am not clear on.
I understand that ##A=\phi(G)##, but do the set ##K## consist of both the permutations ##\sigma## and ##(h)\psi_1.##
For the function ##(h)\psi_1##, it is defined as ##(h) \psi_1 : H\to K## but what about at various places where it says it sends ##A\to Ah,## ##A'## to itself. In terms of elements evaluated by ##\psi_1##, what is the difference between when it sends ##A'## to itself versus ##(a)\psi_1.## Earlier in the proof, it already states that ##(h)\psi_1## sends ##A'## to itself, but ##(a)\psi_1## leaves both ##A## and ##A'## fixed. The notation for the elements of ##\psi_1## are confusing. ##h, a## are elements of ##H, A## respectively, then when it says ##(h)\psi_1## leaves ##A'## to ##A'##, what about ##(h)\psi_1## where it sends ##A## to ##Ah.## Also in the case of ##A## to ##Ah##, does it mean ##a\mapsto ah?## Other points of confusion for me is how do both ##\sigma, (a)\psi_1## and ##\sigma, (h)\psi_1## commute, lastly, how does ##(a)\psi_2=\sigma^{-1}((a)\psi_1)\sigma=(a)\sigma_1.##
Thank you in advance.
Background
Let ##\phi: F\rightarrow G## to mean that ##F## and ##G## are groups and ##\phi## is a homomorphism defined on ##F## and taking values in ##G##. If ##\psi:G\rightarrow H## the composite homomorphism from ##F## to ##H## is written ##\phi\psi.## If ##x\in F## the image under ##\phi## is written ##(x)\phi.## A homomorphism ##\psi## that cancels on the right in every equation ##\phi_1\psi=\phi_2\psi## is a monomorphism. If ##\psi:G\rightarrow H## then ##\psi## is a monomorphism if for each group ##F## and for each pair ##\phi_1, \phi_2## of homomorphism from ##F## to ##G## such that ##\phi_1\psi=\phi_2\psi,## the equation ##\phi_1=\phi_2## holds. A homomorphism ##\phi## that cancels on the left in every equation ##\phi_1\psi=\phi_2\psi## is an epimorphism. If ##\phi:F\rightarrow G## and if an inverse homomorphism ##\psi## from ##G## to ##F## exists - i.e., one such that ##(x)\phi\psi=x## for each element ##x## of ##F## and ##(y)\psi\phi=y## for each element ##y## of ##G##- then ##\phi## is an isomorphism. We prove that "A Group Epimorphism is Surjective".
Proof: Let ##\phi## be an epimorphism from a group ##G## to a group ##H,## and let ##A## be the image subgroup. We must show that ##A=H.## To do this we construct two homomorphism ##\psi_1,\psi_2## from ##H## to a group ##K## such that ##\phi\psi_1=\phi\psi_2,## and we use the resulting equation ##\psi_1=\psi_2## to prove that ##A=H.##
Let ##H/A## be the set of all right cosets of ##A;## let ##A'## be something that is not a right coset of ##A,## and let ##S## be the set ##H/A\cup\{A'\}.## Let ##K## be the group of all permutations (bijections) of ##S.## If ##h,h_1,h_2\in H## and if ##Ah_1## and ##Ah_2## are the same coset, then ##A(h_1h)## and ##A(h_2h)## are the same coset, and hence the function from ##A/H## to ##A/H## that sends ##Ah'## to ##A(h'h)## is well defined. It is easily seen to be bijective. (in fact its inverse is given by ##Ah'\rightarrow Ah'h^{-1}.##) If ##A'## is sent to itself, this defines a bijection of ##S,## which we write ##(h)\psi_1.## The function ##\psi_1## from ##H## to ##K## so defined is easily seen to be a homomorphism. Let ##\sigma## be the permutation of ##S## that interchanges ##A## and ##A'## and leaves everything else fixed, and if ##h\in H## write ##(h)\psi_2## for the composite permutation ##\sigma^{-1}((h)\psi_1)\sigma.## Then the function ##\psi_2## is the composition of ##\psi_1## with an inner automorphism of ##K,## and hence is a homomorphism from ##H## to ##K##.
If ##a\in A,## then ##(a)\psi_1## leaves both ##A## and ##A'## fixed, and ##\sigma## leaves every other element of ##S## fixed Hence ##\sigma## and ##(a)\psi_1## commute, and ##(a)\psi_1=\sigma^{-1}((a)\psi_1)\sigma.## Since ##\psi_1## and ##\psi_2## agree on the range of ##\phi,## the equation ##\phi\psi_1=\phi\psi_2## holds. Since ##\phi## is an epimorphism, ##\psi_1=\psi_2.## Hence ##(h)\psi_1## commutes with ##\sigma## for each element ##h## of ##H.## Since ##(h)\psi_1## leaves ##A'## fixed and ##\sigma## interchanges ##A'## and ##A.## It follows that ##(h)\psi_1## leave ##A## fixed. Since ##(h)\psi_1## sends ##A## to ##Ah,## it follows that ##h\in A.## Since ##h## was an arbitrary element of the group ##H,## it follows that ##A=H## and ##\phi## is surjective.
Questions
