Question about a sheet of charge
  • Thread starter Thread starter toesockshoe
    Charge
The discussion centers on the behavior of electric fields produced by different charge distributions, specifically point, line, sheet, and volume charges. It highlights that the electric field of an infinite sheet of charge is treated as constant, which raises questions about how a test charge far away can experience the same force as one nearby. The approximation of an infinite sheet is acknowledged as a useful simplification, despite its physical limitations, particularly when analyzing fields close to the sheet. When considering finite sheets, the electric field behaves more like that of a point charge at greater distances, complicating the derivation of closed-form solutions. Understanding the assumptions behind these equations is crucial for accurate interpretations of electric fields and forces.
toesockshoe
Today my prof said that for a point charge the force is proportional to 1/r^2. For a line charge it is proportional to 1/r. For a sheet charge it is a constant and for a volume it is proportional to r. He also did some derivations but I don't see how this can be.
For example for a sheet charge how can a test charge that is a million meters away experience the same force that an object one millimeter away experiences? Then doesn't that mean if I make a sheet charge of say 100C, then I should be able to provide a resulting force on an object that is across the country ... because a sheet charge produces a uniform electric field regardless of position right? Obviously this doesn't happen because if someone create a sheet charge in Africa...a metal object here certainly doesn't not feel it all the way here in America. Same thing with a volume charge... How can an object further away from the charge feel a stronger attraction than something closer to the charge?
It's always important to understand what assumptions are made when deriving these kinds of equations. In particular, the assumption when deriving the electric field of a sheet of charge is that the sheet is infinite in extent. Obviously, this is not physical, but it is a good approximation when looking at the electric field close to the sheet. It's like the acceleration due to gravity. Certainly objects don't always accelerate with an acceleration of ##g## (after all, the force decreases as you get farther from the Earth), but when close to the surface, it is a good approximation to treat the gravitational field as a constant.
If the sheet is finite, then at far distances, it will look like a point charge. Then you can imagine what the formula will look like, however, from searching around, it is very difficult to get a closed form solution for a finite sheet of charge, hence the infinite sheet approximation.
Thank you.
axmls said:
IIf the sheet is finite, then at far distances, it will look like a point charge. Then you can imagine what the formula will look like, however, from searching around, it is very difficult to get a closed form solution for a finite sheet of charge, hence the infinite sheet approximation.
If the sheet is a finite disc, and the particle lies on the axis of the disc, the math for the field (multiply by charge of particle in the field to get the force) is shown here:
http://hyperphysics.phy-astr.gsu.edu/%E2%80%8Chbase/electric/elelin.html#c3
rcgldr said:
If the sheet is a finite disc, the math for the field (multiply by charge of particle in the field to get the force) is shown here:
Ah, of course. My brain instantly jumped to a finite rectangular sheet. Yes, a disc has a very simple closed form along the axis through its center, and I'm sure the OP can confirm that we obtain the formula for an infinite sheet if we let the radius go to infinity.
It the sheet is a rectangle and the particle lies on the central "axis" of the sheet, the sheet could be considered as an infinite number of lines of finite length, where the component of force perpendicular to the lines cancel, so only the component related to z needs to be considered. This is the math for a line, the math for a sheet would involve an integral based on the formula for a line:
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elelin.html
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
