Question about Auto-Ignition Temperature
  • Thread starter Red_CCF
  • Tags
    Temperature
In summary, at the auto ignition temperature (AIT), the fuel and oxidizer/air mixture will not combust spontaneously. The flash point and flame point are different temperatures, depending on the mixture, and the ignition temperature is irrelevant.
Red_CCF
532
Hello
I was wondering about explanation of the auto ignition temperature (AIT). From the definition in ASTM E659:
AIT (auto-ignition temperature) is the lowest temperature at which the substance will produce hot-flame ignition in air at atmospheric pressure without the aid of an external energy source such as spark or flame. It is the lowest temperature to which a combustible mixture must be raised, so that the rate of heat evolved by the exothermic oxidation reaction will overbalance the rate at which heat is lost to the surroundings and cause ignition.
What I get from the last sentence is that fuel-air reaction at some level occurs at any temperature, but the number of particles reacting is not large enough to produce enough energy for sustained combustion until fuel temperature is above AIT. Is any of the two following reasons for this correct:
1) Higher temperature means higher reaction rate from Arrhenius's equation
2) Higher vapour pressure due to the higher liquid temperature
Is there an assumption behind what the oxidizer temperature for fuel AIT? In ASTM E659, the experiment involves heating a small quantity of fuel inside a large flask of air at a pre-determined temperature, but since they are heating the flask I'm not sure how it is possible to control the temperature of the air.
Thank you very much
You should check out
Flash Point - lowest temperature at which the vapours of a fuel will ignite from the introduction of an ignition source.
Flame point - lowest temperature at which the fuel vapours will continue to burn after being ignited.
Auto Ignition Temperature - lowest temperture at which the fuel will spontanously combust without introduction of an ignition source.
Flash point and Flame point can be different temperatures, in which case the vapours at flash point will cease combustion once the ignition source is removed; or similar temperatures in which case the vapours will continue combustion.
As an example, gasoline and air mixture is compressed in the cylinder of the automobile engine. The compression heats the mixture to a temperature somewhere above the flash point but below the AIT. The ignition source is the spark from the spark plug.
I have a couple of questions
1. Are all of these quantities empirical (i.e. we can't calculate the Flash Point or AIT etc.)?
2. For Flash and Flame Point, why is the ignition temperature irrelevant, as a higher ignition temperature would add more energy to the system?
3. When we do tests to determine these quantities, is there an assumption of thermal equilibrium between the fuel and oxidizer/air?
4. Was my hunch in my OP about AIT correct?
Thank you
Related to Question about Auto-Ignition Temperature
1. What is auto-ignition temperature?
Auto-ignition temperature is the lowest temperature at which a substance will spontaneously ignite without the need for an external flame or spark.
2. How is auto-ignition temperature measured?
Auto-ignition temperature is typically measured using standardized laboratory tests, such as the ASTM E659 or the ISO 871 method. These tests involve heating a sample of the substance in a controlled environment until it ignites.
3. Why is auto-ignition temperature important?
Auto-ignition temperature is important because it provides valuable information about the potential fire hazards of a substance. Knowing the auto-ignition temperature can help prevent accidents and ensure safe handling and storage of the substance.
4. How does auto-ignition temperature differ from other flammability measures?
Auto-ignition temperature differs from other flammability measures, such as flash point and fire point, because it is the temperature at which a substance will ignite on its own without the need for an external ignition source. Flash point and fire point, on the other hand, require an external flame or spark to ignite a substance.
5. Can the auto-ignition temperature of a substance change?
Yes, the auto-ignition temperature of a substance can change depending on various factors such as pressure, oxygen concentration, and the presence of impurities. It is important to regularly test and monitor the auto-ignition temperature of a substance to ensure safety and accuracy.
  • Materials and Chemical Engineering
  • Mechanical Engineering
  • Chemistry
9K
20K
