Question about chemical nomenclature
The discussion centers on the existence of cis and trans forms of 1,3-dibromo-1,3-dimethylcyclobutane. The distinction is clarified through the examination of 3D structures, where the trans configuration places substituents on opposite sides, while the cis configuration has them on the same side. It is noted that the molecule cannot rotate around the axis of the single bonds due to the rigidity of the cyclobutane ring, which requires breaking a bond or forcing a methyl group through the ring to interconvert between the two forms. The participants express gratitude for the clarification provided.
yeung2743
I want to know why there are cis- and trans form of 1,3dibromo-1,3-dimethylcyclobutane?
and anybody explain it to me thanks a lot
Chemistry news on Phys.org
If you look at the 3d structures it should be fairly obvious
Trans ("other side") to the right, cis (same side") to the left.
and it can't rotate around the axis of the single bond
No, there are two single bonds locking it in a stiff ring so you either have to break a bond or squeeze a methyl group through the center of the ring to interconvert them.
I understand now
Thx all you three guys ^^
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
