Question about direction of movement of water molecule
When a boat moves to the left, water molecules beneath it also shift left due to Newton's third law, where the friction force from water acts to the right. This interaction leads to a corresponding force on the water molecules, causing them to move in the same direction as the boat. At lower speeds, this relationship holds well, but complications arise at higher speeds due to turbulence and vortices. The application of Stoke's law is limited by factors such as viscosity, speed, and size, which are encapsulated in the Reynolds number. Understanding these dynamics is essential for accurately predicting water movement in various conditions.
songoku
This is not homework. I want to ask about the direction of movement of water molecules at 1:44 from this video
https://www.youtube.com/watch?v=UVcyea3ZH54
Newton's 3rd Law
When the boat moves to the left, water molecules below it also move to the left.
Is it correct to say the reason is because of Newton's 3rd law? Water molecules provide friction force to the boat so force on boat by water molecules is to the right. By Newton's 3rd law, there will be force on water molecules by boat in opposite direction so the force on water will be to the left, then water molecules will move in the same direction as the boat.
Thanks
Your description is pretty good, particularly for small speeds (small compared to what? is a good question). At higher speeds life gets much more complicated because of vortices and turbulence but one step at a time...
I know the formula of Stoke's law
$$F=6 \pi \eta vr$$
Is there a speed limit to apply Stoke's law?
And will turbulence change the direction of motion of water molecules so the water molecules may move to opposite direction (to the right)?
Thanks
Look up Reynold's number. This depends upon viscosity and speed and size in an interesting and complicated fashion. Not easy stuff.
Thank you very much hutchphd
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
