Question about Euler’s Equations when Auxiliary Conditions are Imposed
In summary: Then do the same for the RHS and multiply through by ##\frac{\partial g}{\partial z}##. This yields the two equations 6.68.
sams
In the Classical Dynamics of Particles and Systems book, 5th Edition, by Stephen T. Thornton and Jerry B. Marion, page 220, the author derived Equation (6.67) from Equation (6.66) which is the following:
Equation (6.67):
$$\left(\frac{\partial f}{\partial y} − \ \frac{d}{dx}\frac{\partial f}{\partial y^′}\right)\left(\frac{\partial g}{\partial y}\right)^{−1} = \ \left(\frac{\partial f}{\partial z} − \ \frac{d}{dx}\frac{\partial f}{\partial z^′} \right) \left(\frac{\partial g}{\partial z} \right)^{−1}$$
Because ##y## and ##z## are both functions of ##x##, the two sides of Equation (6.67) may be set equal to a function of ##x## which we write as ##\lambda(x)##:
Equations (6.68):
$$\frac{\partial f}{\partial y} − \frac{d}{dx}\frac{\partial f}{\partial y^′} + \lambda(x)\frac{\partial g}{\partial y} = 0$$ $$\frac{\partial f}{\partial z} − \frac{d}{dx}\frac{\partial f}{\partial z^′} + \lambda(x)\frac{\partial g}{\partial z} = 0$$
where ##\lambda(x)## is the Lagrange undetermined multiplier.
How did the author deduce Equations (6.68) from Equation (6.67)?
Any help is much appreciated. Thank you so much.
Equation (6.67):
Equations (6.68):
Almost exactly as described: e.g. take the LHS of 6.67 and write that it equals -λ(x). Multiply through by ##\frac{\partial g}{\partial y}##.
Related to Question about Euler’s Equations when Auxiliary Conditions are Imposed
1. What are Euler's equations and why are they important in science?
Euler's equations are a set of three differential equations that describe the motion of a rigid body in a three-dimensional space. They are important in science because they provide a fundamental understanding of the dynamics of rotating objects, which is essential in fields such as mechanics, physics, and engineering.
2. What are auxiliary conditions and why are they necessary in Euler's equations?
Auxiliary conditions, also known as initial or boundary conditions, are additional constraints that are imposed on Euler's equations to fully determine the motion of a rigid body. They are necessary because the equations alone cannot determine the motion without these additional conditions.
3. How do auxiliary conditions affect the solutions of Euler's equations?
The auxiliary conditions determine the specific solution of Euler's equations, as they restrict the possible motions of the rigid body. Without these conditions, there would be an infinite number of solutions for the equations.
4. Can you provide an example of an auxiliary condition in Euler's equations?
One example of an auxiliary condition is the initial angular velocity of a rigid body. This condition specifies the initial rate of change of the body's orientation, which is necessary to fully determine its motion.
5. How do Euler's equations with auxiliary conditions relate to real-world applications?
Euler's equations with auxiliary conditions are used in real-world applications to study the motion of rotating objects, such as gyroscopes, satellites, and other mechanical systems. They provide a mathematical framework for understanding and predicting the behavior of these objects, which is crucial in fields such as aerospace engineering and robotics.
  • Classical Physics
  • Classical Physics
  • Classical Physics
