Question about forces in a gearbox
In summary, the output torque on the worm gearbox 10:1 when the electric motor is working on 1 kw at 1500 rpm will be 47.5 N.m.
Kiko
hi all
i have a simple question but answer i don't know how to find :)
lets say we have a electric motor with 1kw at 1500 rpm and that is 4.75 N.m
when the electric motor is connected to worm gearbox n proportion 10:1 then the speed on output point of the gearbox will be 150 RPM. But this mean also that the torque on output point of the gearbox is increased, and that is 9.x kw, let's say 9 kw.
In this case, when we have 9 kw on output point of the gearbox with output speed 150 rpm then: output torque will be 427 N.m
i am correct or?!
If not, then let me know how much torque on N.m i will have on output point of the worm gearbox 10:1 when source el.motor is working on 1 kw with speed 1500 rpm.
im based on calculations on http://wentec.com/unipower/calculators/power_torque.asp
thank you
Kiko said:
hi all
I used the calculator at the site you linked, and I got 6.37 N.m when I input 1kw and 1500 rpm.
Here, I think, is the root of your confusion. Changing the gear ratio changes torque, not power. If you have a 1kw motor, you will get 1 kw out the end, regardless of gearing. So, try figuring your output torque again, bearing in mind that the horse power (or kw, in this case) will not be changed. I think you’ll like it, because the math is actually easier than you have been doing.
Likes russ_watters
ok
Kiko said:
ok
Use the calculator to get the input torque. Multiply it by your gear ratio.
@Kiko You need to be applying the equations that you already know in the right way or the answers will not be valid. Your initial calculation implies more power out than power in and you have to smell a rat in that answer.
Input torque will be (Input Power) / (input angular speed)
Ideally, Output torque and output speed will be scaled according to the gear ratio. Output Power will be (output torque) x (output angular speed)
That is a very theoretical answer, of course. A worm gear is very inefficient (which is why they don't work backwards) and the output Power will be significantly less than the input Power.
Basic theory about Machines in general uses two quantities.
Velocity Ratio - which is the ratio of the input and output speeds and which is just based on the geometry of the machine.
Mechanical Advantage - which is the actual ratio of forces or torques at output and input.
Efficiency = MA/VR (always less than one, of course)
People tend to use just Velocity Ratio in their calculations and then they get over optimistic ideas about the likely performance of their machine. Worse still - they refer to that as Mechanical Advantage. You will even find that practice all over PF threads. Tut tut.
Likes jrmichler
@sophiecentaur
ok, thanks for your answer, but nothing i understand here... sorry about that. But my question is simple and concrete, also i need simple and concrete answer, sure, if you would like :)
how much torque on N.m i will have on output point of the worm gearbox 10:1 when source el.motor is working on 1 kw with speed 1500 rpm?
thanks
Kiko said:
@sophiecentaur
thanks
Multiply your input torque by the gear ratio.
Kiko said:
hi all
when the electric motor is connected to worm gearbox n proportion 10:1 then the speed on output point of the gearbox will be 150 RPM. But this mean also that the torque on output point of the gearbox is increased..
Correct. The rpm reduces by 1/10. The torque is increased by *10 so 47.5Nm.
No you made a mistake somewhere. No gearbox can produce more energy out than it consumes.
If there are no friction losses in the gearbox the power output will be unchanged (eg 1kw in = 1kw out). However real gearboxes aren't 100% efficient. I think typical worm drive gearboxes are 80-90% efficient so you should only expect 800-900W output with 1000W input.
Kiko said:
hi all
lets say we have a electric motor with 1kw at 1500 rpm and that is 4.75 N.m.
Actually 4.75Nm at 1500rpm isn't 1000W...
1500rpm = 157rads/s
157*4.75=740W
So did you mean a 1HP motor? Eg A motor that delivers 750W? That might consume 1000W if its only 75% efficient.
1500rpm = 157rads/s
157*4.75=740W
look like you are correct. Great! thanks
1 kw = 1.34 HP
my main goal is to mount the 1 kw electromotor to the worm gearbox 10:1 like source of power.
1 kw = 6.37 Nm torque
then how much torque will be n output point of the worm gearbox 10:1?
thanks CWatters
Only at one operating speed.
You have already been over (more than once) how torque and speed are related, for a given power. So, if the speed is divided by ten in the worm gear, you can say what happens to the torque. You do not actually need to be told that explicitly, do you?
Likes russ_watters
Please tell me you can multiply or divide a number by 10 in your head!
Likes sophiecentaur
1 kw = 1.34 HP
I don’t think anyone has mentioned this to you yet, but people in these Forums will almost never just spit out an answer like that. It wouldn’t exactly be violating any rules, but it would be frowned upon; sort-of goes against the overall mission of this site, which is to increase scientific understanding. We are all trying to show you the right direction to find the answer yourself, and point out any missteps we can see that are keeping you from finding it.
Just thought you should know, nobody’s trying to be evasive or rude, just trying to stay true to our mission. So, take your best shot at what you think the answer is, and why, and we will help as much as we can. Based on what you’ve said so far, it looks like you probably know the answer.
Likes berkeman and sophiecentaur
It's general rule that, if one wants specialist information that can be relied on, it will cost you money because you will need to pay a professional for it. So many people who ask for information on PF seem to think they are 'customers' with customer rights. Strange when you think of the hours of input that a well presented appeal for help from a can elicit from PF when the questioner is prepared to make a bit of an effort.
Ok, that's enough. Thread locked.
Edit by Mark44 -- A number of substandard posts and rants have been deleted.
Related to Question about forces in a gearbox
1. What is a gearbox?
A gearbox is a mechanical device that uses a series of gears to transmit power from one source to another, typically used to change the speed, torque, or direction of a rotating shaft.
2. How does a gearbox work?
A gearbox works by using a sequence of gears with different sizes to change the speed and torque of the input power. The input shaft turns the first gear, which then turns the second gear, and so on, until the output shaft receives the desired speed and torque.
3. What are the types of forces involved in a gearbox?
The types of forces involved in a gearbox are primarily compression, tension, and shear forces. Compression forces are experienced when two gears are in contact and pushing against each other. Tension forces occur when the gears are pulling away from each other. Shear forces are caused by the sliding motion between gear teeth.
4. How do forces affect the performance of a gearbox?
Forces in a gearbox can greatly impact its performance. Too much compression or tension can cause gears to wear out quickly, leading to a shorter lifespan of the gearbox. Additionally, excessive shear forces can cause gear teeth to break or wear down, resulting in decreased efficiency and potential damage to the gearbox.
5. How can forces in a gearbox be managed?
To manage forces in a gearbox, proper lubrication, material selection, and gear design are crucial. Lubrication helps reduce friction and wear on the gears, while selecting appropriate materials for the gears can ensure they can withstand the necessary forces. Additionally, optimized gear design can distribute forces evenly, minimizing wear and increasing the overall performance of the gearbox.
