Question about friction? Dynamics
The discussion centers on understanding the direction of the frictional force acting on a car on a ramp. It highlights that friction opposes the tendency to slip down the ramp, which can lead to confusion about its direction. When the car moves too fast, friction acts down the ramp to maintain circular motion, while slower speeds require friction to act up the ramp. The importance of drawing a free body diagram (FBD) is emphasized to analyze the forces at play. Overall, the conversation clarifies the role of friction in maintaining stability on inclined surfaces.
Ricardeo Xavier
This is the problem
http://imgur.com/a/1XFlt
2. Homework Equations
This is the given FBD
http://imgur.com/a/CURqA
3. The Attempt at a Solution
Now the car should have a tendency to slip down the ramp thus causing the frictional force to oppose this motion. But the frictional force is pointed down the ramp in this worked out problem. Can someone explain to me why this is?
Why is friction pointed down the ramp? Shouldnt it be pointed up the ramp?
If there were no ramp (i.e. the ground was flat) and the car was going around a curve, what direction would the friction force have to point?
Note that they ask for minimum and maximum speeds. What happens when you take the curve too fast? Which direction do you tend to slip?
Follow the sequence of the questions asked by the problem.
First draw the FBD to determine how fast the car must be moving if there were no friction, i.e. sliding around a frictionless curve.
If the car is moving faster than that, friction down the incline is needed to keep it in a horizontal circle.
If the car is moving slower than that, friction up the incline is needed to keep it in a horizontal circle.
Thanks everyone for the great responses! It really helped clarify things for me (:
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
