Question about Gravity and curvature of space time
In summary, the curvature of space-time, as described by Einstein's theory of General Relativity, is responsible for the force of gravity. An object remains in orbit because of this curvature, and the same curvature allows objects to fall towards the center of mass. The force pulling on an object towards the center of mass is gravity, and the curvature of space-time dictates how the object moves. The concept of relativity must be considered when discussing stationary objects, as everything is in motion relative to something else. The curvature of space-time does not give objects a nudge, but rather is the underlying cause of gravity.
Christine88
24
Hello all
I just joined this forum so forgive me for jumping right in but I have a question about Gravity and the curvature of space time that I can't get answer with a Google search. My question: though I understand that an object remains in orbit because of the curvature of space time and it is this curvature which is responsible for Gravity, but what causes an object that is stationary to fall toward the center of mass if nothing sets it in motion? Does the curvature of space give it a nudge? If so How? Why does a ball which is motionless in my hand fall if I let go of it without giving a push? I understand that if I set it into motion fast enough that it will fall around the Earth following the curvature of space but what makes it move toward center of mass if no force is acted on it?
What happens if you place a ball on a ramp and let go?
It rolls down the ramp. But what sets it in motion?
The downwards acceleration of gravity. Perhaps that analogy wasn't as helpful as I was hoping.
In regards to "Why does a ball which is motionless in my hand fall if I let go of it without giving a push" - what you need to wonder is, "why does the ball not always fall to the ground, if gravity is always acting on it?" - The ball remains in your hand, because you are providing an opposing force to gravity - the feeling of weight of the ball. If you remove your hand, you are no longer providing that opposing force, and the net force is downwards, so the ball falls.
What is the force pulling on it? The curvature of space dictates how the ball moves but why it is being pulled toward the center of mass?
The force pulling on it is gravity. The force of gravity acts towards the centre of mass, because that's how it acts based on all of our observations. "Why" questions are unfortunate in physics, you rarely get a satisfactory response.
Do you intend to ask about how the curvature of space-time leads to the experience of gravity?
The same thing that allows the object to remain in orbit also allows an object to fall down. If you understand the one, then you understand the other. I should be able to answer you better if you explain how, by your understanding, the curvature of space-time keeps an object in orbit.
Meantime: what do you mean by "stationary" - OK the object is not moveing: but relative to what?
Everything is in motion with respect to something - when you talk about relativity then you have to specify what things are stationary with respect to.
No.
Same reason it does not fall if you are in free-fall when you let it go.
What education level do you need the answers to?
Take a look at this animation (created by member A.T.):
Welcome to PF Christine,
You are a quite curious one and that quality is appreciated over here. The question you are asking is about the fundamental or I should say that its about the natural property of a mass. The curvature of space-time is just a geometrical representation given by Dr. Einstein about gravity and as it is useful in understanding the concept of gravity on large scale, its generally accepted as a representation model for gravity. For your question, its generally accepted that a curvature of space-time leads to the force of gravity.(At least not until now, anyone has tried to raise question about the fundamentals of GR:L) One has to accept certain postulates to get the desired result from a theory. I hope you got my point.:)
Christine88 said:
Hello all
You're thinking of ordinary curvature of space, not space-time. Although curvature of space is present in General Relativity and affects very fast-moving objects and light, the main effect of gravity can be described in terms of curvature of space-time with respect to time. That has the effect that if you draw a line representing the path of a particle through space-time (which for a slow-moving particle travels ct in the time direction while it travels distance vt in the spatial direction of travel) then if you look at the direction of that plotted against time you find that it curves towards the gravitational source.
(The word "curvature" in this ordinary sense of plotting a curved path against a coordinate grid is not the same as the intrinsic "curvature" caused locally by mass in General Relativity, which is more like the curvature of the surface of a ball, and is effectively measured by the way in which the total angle around a closed path differs from the normal flat space value).
https://www.physicsforums.com/threads/question-about-gravity-and-curvature-of-space-time.778417/goto/post?id=4893782#post-4893782
I think so yes. But from what I gather no one really knows
No. Same reason it does not fall if you are in free-fall when you let it go.
I'll reply at lunch when I have more time. I'm at work right now but thank you for the reply.
Stationary with respect to the curved space of the object it orbiting.
So space is not really physically curved by a mass?
No such thing ... something moves with respect to another object in space.
Anyway - I thought you were asking about a space-time description?
Now you are switching to space alone? Please make up your mind.
How can anyone "really know" anything? What does that even mean?
I have a feeling you are trying to explore philosophical issues.
Unless you can ask clear questions you are unlikely to get helpful answers.
General relativity is a mathematical framework that can be used to describe the geometry of events in space-time.
The effect of energy in this framework is to give the space-time manifold an intrinsic curvature depending on the energy density distribution.
We have evolved to model events as a progression of 3D space events in a distinct time dimension ... when you make the projection from space-time for a particular observer in 3D space watching events unfold over time you get a mysterious force pulling high-density pockets of energy together. This is understood as a pseudoforce similar to the centrifugal force in a rotating room or the way objects get pulled to one wall when a room is accelerating.
The "reality" of this intrinsic curvature is a philosophical issue - which we won't go into here - in science the reality of a mathematical model depends upon it's empirical foundation: how good is it at predicting the results of experiments, and how hard have people tried to find an experiment that it does not predict? In that sense the intrinsic curvature is as real as any other well-supported model.
Christine88 said:
Hello all
It may be useful to note that in contrast with the way you formulated it, GR according to Einstein is practical about "space" and "time", interpreting those concepts as tools to describe observations [1]. GR thus provides an improved and verifiable description of effects of gravitational fields, free from metaphysical claims. A very nice and clear graphical illustration was provided in post #8.
Also, for sure gravitation is not like "rubber bands" pulling on objects; there is no force involved in that sense. Nevertheless, GR is a field theory [2]. Perhaps a good way of looking at it, is that all objects have a natural tendency to move towards mass as described by GR.
Regretfully I did not find a direct answer to your question as I understand it in the peer reviewed literature (I have searched for the same). Perhaps there is a publication that I'm not aware of. I did find a reasonable looking answer by "Googling" on the Internet but it's not allowed to ask here for highly valued comments by specialists! o0)
As a substitute, what I personally found helpful is the explanation of why light bends towards mass according to Einstein, here, from p.821 (this is also known as "gravitational lensing"): https://en.wikisource.org/wiki/The_...Perihelion-motion_of_the_paths_of_the_Planets.
[1] Einstein, "Relativity, the special and general theory", Minkowski's four-dimensional space - http://www.bartleby.com/173/17.html
[2] Einstein, "Relativity, the special and general theory", The Gravitational field - http://www.bartleby.com/173/19.html
I think that the key thing that you are missing is that GR considers gravity to be the curvature of spacetime, not just space. A "stationary" object is still "moving" through time. So nothing in gravity needs to set it in motion, it is already moving. All that needs to happen is for the curvature to cause some of the "motion" through time to curve into motion through space.
I don't think this is helpful. The OP asks about the GR model, where gravity is modeled via space-time geometry, not via a pulling force.
Now you are switching to space alone? Please make up your mind.How can anyone "really know" anything? What does that even mean?
Sorry I guess I have gotten myself in trouble here. I'm an engineering student not a physicists.
Also this very similar one, with more explanation, and the case of vertical upwards throw:
Space-time is curved, and the time dimension crucial for gravitational attraction. Space (without time) is also curved, but that is not mainly relevant for gravitational attraction. The pictures here might be helpfull:
http://www.physics.ucla.edu/demoweb..._and_general_relativity/curved_spacetime.html
http://www.relativitet.se/spacetime1.html
Ok now I think I get it. Because space and time are the same any object in space is already in motion through time?
... Well, from an engineering perspective, space-time is really curved in the same way that the centripetal force is the real force in rotational motion. We can do our maths either way but one way has less voodoo. Newton's gravitation has this spooky "action at a distance" thing (how does an object know about the mass some way away that it is supposed to fall towards?)
You seem to be getting there though.
Is that correct?
Yes, essentially. There are a few mathematical subtleties about how time is different from space, but they are part of the same mathematical structure (called a pseudo Riemannian manifold), so in essence that is the correct idea.
Thank you!
DaleSpam's is the direct answer to your question; everything is always in motion through spacetime. Mathematically this is encapsulated by a vector called the four-velocity. You should be able to find many resources on this at various levels, but to reiterate, everything is always in motion through spacetime, so it doesn't need any initial nudge to start falling.
Say you are holding an apple. You are diverting the apple from following its natural path through spacetime, by exerting a force on it which you feel as its weight. When you let it fall the apple reverts to its natural path. The name of this natural path is the geodesic. Hope this helps.
Why do objects accelerate when falling as opposed to a constant velocity?
Photons falling vertically at light speed, do stay at a constant velocity, and do not accelerate any further.
Otherwise see the video below, and note how the straight world line the starts along time, and then becomes more and more along space. That is acceleration in space.
Yes I understand that light speed is always constant in a vacuum, slows down in a medium, but I'm afraid I don't get that video.
I'm afraid one cannot simplify it much more than that video. Try the other one, with more explanation:
  • #31
Well, in some way they do accelerate but in the way we prefer to state it, there is no acceleration!
I think this is a good explanation:
Just consider the sun-earth system. When you look at the whole Earth's world-line, from some other place with a different gravitational field-maybe a vanishing one-you see there that the world-line is curved, because its the geodesic of the space-time in that part of it and is generally different from the geodesic of the space-time in a different part of it. But space-time is always locally(when you only pay attention to your near vicinity) flat(Minkowskian) and locally the world-line is a straight line in space-time. This way, the object is going with constant velocity at every point of space-time and so we should accept its always going in constant velocity. The only point is, because of the curvature of space-time, the distance the object travels and the time in which the object travels that distance, are changing through its world-line only because of the change in space-time through the object's world-line, i.e. as the object goes in its world-line the rods and clocks change because space and time themselves change.
  • #32
Like lots of other things, in relativity acceleration is relative. Suppose you throw a ball up in the air while you are stood on the ground. The ball accelerates relative to you, but, equally, you accelerate relative to the ball. If I am nearby, jumping on a trampoline, then while I am in the air I see you accelerating upwards relative to me, and I see the ball moving at a constant velocity relative to me.
In general relativity we measure acceleration (or more accurately "proper acceleration") relative to falling objects, i.e. "inertial" means falling freely under gravity.
  • #33
I think one more piece is required to fully comprehend "why": Gravity is virtually indistinguishable from acceleration through space which nicely removes the time factor for simplified comprehension. Imagine standing in a rocket in empty space on a floor perpendicular to acceleration. If you hold a ball, your hand is accelerating it and if you let go it stops accelerating with you and the floor accelerates to reach it. I hope that helps!
  • #34
I think I've heard that called the law of equivalents?
  • #35
The guy in the video lost me when he retuned the graph back to zero gravity and then proceeded with his explanation as though there was still gravity. How could that be if the graph was returned to zero gravity? So this is how I understand it. Let us imagine a little moon sitting out in space all by itself and absolutely motionless relative to the rest of the universe. No gravitational influences effecting it. In fact it is the only object in the universe so it's at absolute equilibrium. I assume from what I have gathered here that our little moon is still moving through time and since space and time are equivalent it's moving through space as well. So I guess a rest state is just an illusion. Anyway God decides to give the lonely little moon a companion and creates a large planet right next to it. Since the little moon is already in motion through space-time it falls toward the large planet without the need of an external force to get it moving because it's already in motion. Does that sound right? I still don't get the acceleration though.
