- 5,925
- 3,114
@Calstiel I can read German reasonably well=I studied it a lot in both high school and college. I looked through the German article somewhat carefully, and they seem to be doing a similar derivation that Hyperphysics does, but they explicitly use ## v_{rel}^2 ##, perhaps because using ## v_{rel} ## as Hyperphysics does gives the problem that I pointed out.
In the German paper method of doing this calculation, they work with ## \bar{ v_{rel}^2} ##, in which case you get a cosine term that is not nested in an expression in a root sign, so it will then average to zero. In that case, you then get ## \sqrt{2} ## instead of the 4/3 I got for the final result, (in their case after converting from ##v^2 ## to ## v ##).
I'm willing to go along with the ##\sqrt{ 2} ## as being a reasonably accurate result. In the case I have, with the cosine expression inside the root sign, I think it is necessary to assume that the speeds are all the same, and just in arbitrary directions. Without the root sign, the speed distribution doesn't matter, because the cosine term does indeed average to zero, without any correction like I found.
Thank you very much for posting the "link". :)
