I Question about Inverse Derivative Hyperbola function
The discussion centers on confusion regarding the application of the hyperbola formula X^2 - Y^2 = c^2 in solving an equation. The user mistakenly squared the Y^2 value too early in their calculations, leading to incorrect results. They recognize the need to square both sides properly to simplify the equation correctly. A suggestion is made to learn calculus fundamentals, such as the chain rule, to improve their mathematical approach. The conversation emphasizes the importance of following logical steps in mathematical problem-solving.
Vividly
TL;DR Summary
Question about inverse Tanhx
Im confused about a certain part of solving an equation. So I used the hyerbola formula to find the answer but I think I did the math wrong.
X^2-y^2=c^2
X=1
Y= (2x^5-1)^2
I did the calculations as you can see in the picture but I know I messed up on the square root part. When you square one side you have to square the whole other side.
So Far I got
1^2-((2x^5-1)^2)^2 =c^2
And as you can see in the picture the math is incorrect due to the process that's suppose to be done in math. When I square both sides I get a different answer when I simplify.
As you can see on the paper that where I am stuck because the answer is 5/2x-2x^6
Mathematics news on Phys.org
Vividly said:
Summary:: Question about inverse Tanhx
X^2-y^2=c^2
X=1
Y= (2x^5-1)^2
So Far I got
As I mentioned on your previous post, it's not possible to keep trying to do calculus this way. Triangles and graphs get you started, but eventually you should learn the chain rule and the algebra of differentiation.
When you go wrong, then you are asking a lot for someone to take the time and effort to analyse this personal and peculiar approach - since no one else does it this way.
Perhaps someone else will have the time to look at this, but my advice is to start doing calculus properly.
There are different ways of doing math. As long as you follow the logic you can solve the problem. I do math in a way that I understand. I figured out what I did wrong. I was squaring the y^2 value to early in the problem. I was suppose to do it at the end to eliminate the square root.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
