Question about mathematical equality
The discussion focuses on understanding a mathematical equality presented in Jackson's "Classical Electrodynamics." A user seeks clarification on the integration by parts method applied to the current density vector, J. The explanation involves expressing J in Cartesian components, integrating each component, and applying boundary conditions that assume J approaches zero at infinity. It is noted that the equality relies on the divergence of J being zero, and the derivation confirms that the integral identity holds true regardless of whether J is a solenoidal field. The conversation concludes with a clarification that the integral identity is generally valid, even in cases with additional variables.
Mr. Rho
Hi there, I am reading Chapter 9 of Jackson Classic Electrodynamics 3rd edition, and I don't see why this equality is true, it says "integrating by parts", but I still don't know... any help?
http://imageshack.com/a/img673/9201/4WYcXs.png
Write \mathbf J as the sum of its Cartesian components and then write the integral as the sum of three integrals of the three Cartesian components. Then integrate by parts each integral, but the J_x w.r.t. to x and so on! If you consider the integrals to be from -\infty to \infty and take \mathbf J to be zero at infinities, you'll get what you want.
That equality depends on div J=0 (or d\rho/dt=0).
Just my derivation. For an arbitrary constant vector ##\vec{n}## we have
$$\vec{\nabla} \cdot [(\vec{n} \cdot \vec{x}) \vec{j}]=(\vec{n} \cdot \vec{x}) \vec{\nabla} \cdot \vec{j} + \vec{n} \cdot \vec{j}.$$
Now integrate this over the whole space and assume that ##\vec{j}## goes to 0 quickly enough at infinity (or most realistically that it has compact support). Then the left-hand side vanishes, because it's a divergence, and thus can be transformed to a surface integral, which vanishes at infinity, if ##\vec{j}## vanishes quickly enough. This implies
$$\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x} \; \vec{n} \cdot \vec{j} = -\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x} \; (\vec{n} \cdot \vec{x} ) \vec{\nabla} \cdot \vec{j}.$$
Now use for ##\vec{n}## the three basis vectors of a cartesian reference frame, and you see that the vector equation stated by Jackson holds.
It's independent of whether ##\vec{j}## is a solenoidal field or not. Of course in the case of stationary currents it must be one, but the integral identity is generally valid.
Sorry about that. I was thinking cases where j appears with other variables.
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
