Stargazing Question about my photos of a Full Moon -- What is this point of light?
  • Thread starter Thread starter Graham 1956
    Astronomy
The discussion centers on a user who captured three photos of the full moon, each featuring a bright point of light in varying positions. The phenomenon, observed in previous photos as well, raises questions about its nature. Forum participants suggest that the light could be a satellite, possibly the International Space Station, due to its visibility and movement across the sky. They recommend using planetarium software to identify the object accurately. Overall, the bright dot is likely not a stationary object but rather a satellite moving relative to the moon.
Graham 1956
I have just taken three photos of the full moon. I am in Southern Spain and the photos were taken around 22.40 (CET).
In each of the three photos, taken within seconds of each other, there is a bright point of light (a dot). In one frame it is in front of the surface of the moon. In the other two frames, it can be seen in the top right quarter of the sky next to the moon (in different positions). A year or two ago, I took a similar succession of photos and saw the same thing. On that occasion, I took more frames and the bright dot could be seen in each of them, but never in the same position. Because of the speed that these frames were taken, it could look like it was a single point of light travelling across the face of the moon and travelling off to the side, and going behind the moon (maybe, that's just fanciful?)
Can anyone explain what this is, please?
I would add the frames here, but I can't see a way to upload photos.
Astronomy news on Phys.org
There should be a button marked "Attach files" just below the reply box. A thumbnail should appear below the reply box once you've selected a file, and it should have a button marked "Insert..." over it. Click that and select Full image.
Or if you are using the reply box in rich text editor mode, click the image button in the bar at the top of the box (it's rectangular with a stylised sun and mountains) and use that option.
Edit: by the way, the forum software automatically resizes large images and small features can be lost. You might want to post the images and also cropped images of just the part with the bright dot. Or host the images elsewhere and link.
Likes russ_watters
Uploading the photos would certainly help, but what you are describing sounds a lot like a satellite. Are you usually able identify satellites when you see them with your naked eye? You can confirm a satellite and which one with planetarium software such as stellarium.
Likes DennisN, FactChecker, berkeman and 1 other person
That would be my guess too. "Going behind the moon" is more likely "going in front of the moon and being lost against a bright background".
Likes russ_watters
The International Space Station comes to mind. It's very visible to the naked eye. It doesn't sound like Elon Musk's Starlink satellites since you would see a string of them.
Likes russ_watters
As the Earth rotates, a geostationary satellite would take about two minutes to cross the full width of the face of the Moon.
Likes russ_watters
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
