Question about new water filter products from South Korea
In summary, two South Korean companies, Wave-Q and Megafresh, have released new water filter models that use a vortex pump to circulate water and a filter filled with alkalis to absorb sediment and decrease water acidity. These companies claim that their products can also arrange water molecules into hexagonal clusters, making it easier for the digestive system to absorb the water. However, there is no scientific evidence to support these claims and it has been revealed that the concept of hexagonal water is a hoax. While the technology used in the pump is interesting, it does not support the companies' claims.
Bararontok
298
There are 2 new models of water filters made by South Korean companies and this is what they claim:
The Wave-Q and Megafresh Filter, both of which are made in South Korea, use a device called a vortex pump to circulate the water in a container. The circulating water is then forced through a filter in the container which is filled with alkalis, and this absorbs sediment, decreases water acidity, and arranges the water molecules into hexagonal clusters that make it easier for the digestive system to absorb the water.
The two companies claim that these devices perform their described functions. Are these claims supported by scientific evidence? Does the hexagonal alkaline water generator produce water that is easier for the digestive system to absorb?
Sources:
www.hexagonalwatersystem.com
www.megafresh.com.tw
Well this doesn't sound right, since an alkali is: "a basic, ionic salt of an alkali metal or alkaline Earth metal element," unless of course they're adding salt to the water...
http://en.wikipedia.org/wiki/Alkali
Any standard activated carbon filter (or many other kinds of filters for that matter) can do this. An "alkali" isn't required...
This might be possible, but of course is assumes water acidity is a problem in the first place...
Now THIS is completely false. Water is a liquid, and can't be arranged in any sort of clusters (unless you freeze it).
I seriously doubt any of their claims are supported, or even descriptive of what the product actually does.
Actually, the thread originator has done research on this and found out that this technology is a hoax.
The following link exposes the concept of hexagonal water as a hoax:
http://en.wikipedia.org/wiki/Hexagonal_water
Although the motor used in the pump was quite fascinating, since the rotor is not mechanically coupled to the commutator and is held in place solely by the forces of the rotating magnetic field and the fact that the rotor is a permanent magnet which makes it stick to the metal base of the pump.
FAQ: Question about new water filter products from South Korea
What are the benefits of using new water filter products from South Korea?
The new water filter products from South Korea offer several benefits. Firstly, they use advanced technology to effectively remove impurities and contaminants from water, making it safe for consumption. Secondly, they are compact and easy to install, making them ideal for both residential and commercial use. Lastly, these products are cost-effective and have a longer lifespan compared to traditional water filters.
How do these water filter products differ from others on the market?
The water filter products from South Korea stand out from others on the market due to their innovative technology. They use a combination of activated carbon, ion exchange, and other filtration methods to remove a wide range of impurities, including bacteria, viruses, heavy metals, and chemicals. Additionally, they have a higher flow rate and require less maintenance, making them more efficient and convenient to use.
Are these water filter products environmentally friendly?
Yes, the new water filter products from South Korea are environmentally friendly. They use natural and non-toxic materials for filtration, and do not produce any harmful by-products. They also have a longer lifespan, reducing the need for frequent replacements and contributing to less waste. Furthermore, some of these products have energy-saving features, helping to conserve energy and reduce carbon emissions.
Can these water filter products be used for all types of water?
Yes, these water filter products are versatile and can be used for various types of water, including tap water, well water, and even rainwater. They have different filtration settings that can be adjusted based on the quality of the water source. This makes them suitable for use in different regions with varying water conditions.
Are there any potential health risks associated with using these water filter products?
No, there are no known health risks associated with using these water filter products from South Korea. In fact, they are certified by reputable organizations and have undergone rigorous testing to ensure their effectiveness and safety. However, it is important to follow the manufacturer's instructions for installation and maintenance to ensure optimal performance and to prevent any potential health hazards.
11K
10K
