B Question about Newton's 3rd law: Two boxes sliding toward each other and colliding
When a 10 kg box is pushed with a 20 N force toward a stationary 5 kg box, it accelerates at 2 m/s² until they collide. Upon collision, the 5 kg box exerts a 10 N force on the 10 kg box, which is an internal force that cancels out with the equal force acting in the opposite direction. This results in a new system where the 10 kg box's acceleration reduces to 1.33 m/s², while the previously stationary 5 kg box accelerates at the same rate. The net external force acting on the 10 kg box is now 13.33 N after accounting for the internal forces. The interaction illustrates Newton's Third Law, where internal forces do not affect the overall acceleration of the system.
inuka00123
imagine a person pushing a 10Kg cardboard box with 20N of force toward a 5Kg cardboard box, with the second law we can calculate it is moving at 2ms/s acceleration toward the 5Kg box, relative to the 10Kg box we can say the 5Kg box is moving toward the 10Kg box with 2ms/s acceleration with a 10N force, when the both boxes collide 5kg box is putting a 10N force to the surface of the 10Kg box. my question is how can we take it as a one system with a 15Kg of mass and 20N force and acceleration with 1.33ms/s, what happens to the opposite forces that act between the boxes when they collide?
They're still there but they have equal magnitudes. So because they act in opposite directions, they cancel out and do not contribute to the overall acceleration of the two-block system. That's a consequence of Newton's Third law. Only external forces to the two-block system can accelerate it. Here, the external force is the 20 N.
Consider this. Someone can grab you by your collar and lift you up by applying an external force on you, but you cannot grab your own collar and lift yourself up. The upward force that your hand exerts on your collar is cancelled by the downward force that the collar exerts on your hand. Try it to see how it works, but be careful not to pull too hard lest you choke yourself or rip your shirt.
No, it could be moving away, slowing down.
They are internal forces.
inuka00123 said:
... when both boxes collide 5kg box is putting a 10N force to the surface of the 10Kg box. my question is how can we take it as a one system with a 15Kg of mass and 20N force and acceleration with 1.33ms/s...
An instant after the boxes collide:
1) The value of the acceleration of the moving 10 kg box gets reduced to 1.33 m/s^2.
2) The value of the acceleration of the 5 kg box that was in repose gets increased to 1.33 m/s^2.
3) The value of the action-reaction contact forces becomes 6.66 N (of opposite directions).
4) The box of 10 kg alone is now being pushed by a net force of 20 N - 6.66 N = 13.33 N, which enables an acceleration of that box equal to 1.33 m/s^2.
5) The box of 5 kg alone is now being pushed by a net force of 6.66 N, which enables an acceleration of that box equal to 1.33 m/s^2.
I undetstand.
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
9K
