I Question about No-Cloning Theorem and State Tomography
Irishdoug
TL;DR Summary
Hi,
I have a question, or am looking for clarification, about the no-cloning theorem and state tomography. My understanding is that the theorem states one cannot make an exact copy of a quantum state. I was also reading about state state tomography where it was said*
'On the other hand, the no-cloning theorem forbids one to create a perfect copy of the system without already knowing its state in advance. Thus, there is no way out, not even in principle, to infer the quantum state of a single system without having some prior knowledge on it [4]. It is possible to estimate the unknown quantum state of a system when many identical copies are available in the same state, so that a different measurement can be performed on each copy. A procedure of such kind is called quantum tomography.'
How can it be, if one cannot create a perfect copy of a state, one can create many identical copies that are in the same state?
Is it the case that you can (attempt to) prepare each state in the same way, but that each state will be slightly different from last?
*ADVANCES IN IMAGING AND ELECTRON PHYSICS, VOL. 128 Quantum Tomography G. MAURO D'ARIANO, MATTEO G. A. PARIS, and MASSIMILIANO F. SACCHI
It means that if you have a quantum mechanical system, and you don't know anything about it, you cannot use it to make identical copies of it. But if you know how it was prepared in the first place, you can simply prepare many systems in the same way. You are not using the given system, you are using the same method of preparation.
Note also that tomography is in practice very often used to test just how well you are able to control/prepare your system.
That is, the assumption is then that the results of of subsequent measurements would end up being nominally identical if you were able to prepare your system with 100% fidelity.
Thanks to both of you.
The no-cloning theorem theorem says that an identical copy cannot be made while retaining the original. An identical copy of an arbitary quantum state can be made if the original state is destroyed, e.g., quantum teleportation (also involves passage of some classical information).
Likes Irishdoug and DrChinese
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
This is still a great mystery, Einstein called it ""spooky action at a distance" But science and mathematics are full of concepts which at first cause great bafflement but in due course are just accepted. In the case of Quantum Mechanics this gave rise to the saying "Shut up and calculate". In other words, don't try to "understand it" just accept that the mathematics works. The square root of minus one is another example - it does not exist and yet electrical engineers use it to do...
