I Question about passive transport of water to the apex of a tree
  • I
  • Thread starter Thread starter shivakumar
    Capillary Tree
Trees transport water to their leaves primarily through transpiration, cohesion, and adhesion in the xylem, rather than through the morphology of nodes and internodes. While capillary action can lift water a few centimeters, it is insufficient for the heights trees can reach, with limits around 120 meters. The anatomy of the xylem allows for the maintenance of fluid columns under tension, even in high humidity conditions where transpiration is minimal. This tension prevents bubble formation, which is crucial for the continuous upward flow of water. Overall, the combination of transpiration and the structural integrity of the xylem facilitates effective water transport in tall trees.
shivakumar
TL;DR Summary
sir, does the anatomy of nodes and inter nodes in stem and branches help the water and minerals to transport leaves at the apex of a tree?
Capillary action can work for few centimeters height but in nature, tree transport water to the leaves in the peak of the tree that are few meter tall by capillary action and transpiration alone. This is a miracle. Is this because of morphology and anatomy of tree? does nodes and internode help in the process of transportation?
Capillary action, in a tree, can possibly draw water up to about 120 metres. That sets an absolute limit to how high a tree can grow on Earth.
The water is transported in the xylem and phloem of a tree.
https://en.wikipedia.org/wiki/Xylem
Likes SammyS, Lord Jestocost and Ibix
shivakumar said:
TL;DR Summary: sir, does the anatomy of nodes and inter nodes in stem and branches help the water and minerals to transport leaves at the apex of a tree?
I think it's key to note that the pores in the leaves (where the water evaporates), are much smaller in diameter than of the xylem below. So the surface tension / capillary action in the pores at the top can be much stronger than in the tubes below, but needs to be transmitted to the fluid below via tension (negative pressure) in the fluid.
Here a good video on this:
Water moves up trees mainly because of transpiration, cohesion, and adhesion in the xylem, not because of the nodes and internodes. Those parts help support the plant but it’s the transpiration pull that gets water to the leaves.
Yes, the continuous upwards flow happens because transpiration.
But a tree must also be able to "hold up" the fluid columns of more than 10m statically, even when no/little transpiration happens. For example, when ambient relative humidity gets close to 100%. Even that static part is not trivial, and requires tension (negative absolute pressure) in the fluid within the long tubes while avoiding bubble formation (boiling).
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
