Question about Quantum Effective Action
wphysics
I am working on Quantum Effective Action in Weinberg QFT vol2 (page 67).
In the last paragraph of page 67, the author said
"Equivalently, ## i \Gamma [ \phi _0 ] ## for some fixed field ... with a shifted action ##I [ \phi + \phi_0 ]## :
i \Gamma [ \phi _0 ] = ∫_{1PI, CONNECTED} ∏_{r,x} d\phi^r (x) exp(iI[\phi+\phi_0])
In this equation, I don't understand two things;
First one is why we have to use a shifted action ##I [ \phi + \phi_0 ]##.
Second one is why we only take into account of one-particle irreducible and connected terms to get Quantum Effective Action for some fixed field ##\phi^{r}_0 (x)##.
Thank you.
Weinberg has also written there that at any place where \phi_0 appears in vertices or propagators within 1PI graph is also a place where an external \phi line could be attached i.e. you can have reducible graphs made of irreducible ones.You can use exp(il-\phi_0) so that you can include disconnected graphs because when doing calculation for n point function those disconnected terms will come out as phases and cancel in numerator and denominator.
Thank you for your answer, but I don't see why your answer is relevant my question and don't understand either.
In previous paragraph in Weinberg book, for general field ##\phi^r (x)##, ##i \Gamma[\phi(x)]## must be the sum of all one-particle-irreducible connected graphs with arbitrary numbers of external lines, each external line corresponding to a factor ##\phi##
I think this is kind of obvious, because we consider ##i \Gamma[\phi(x)]## as action and it gives full amplitudes, so the coupling constants in ##i \Gamma[\phi(x)]## should be the renormalized one, in other words, it has to take into account of all one-particle-irreducible graphs.
But, for fixed field, I don't understand why we have the sum of one-particle-irreducible graphs for the vacuum-vacuum amplitude, which has no external lines, and why we have to use a shifted action.
I am sorry, but could you explain in more detail?
This section is not up to Weinberg's usual standards of clarity. That "integral" is very weird; in particular, the measure isn't invariant under shifts of the field. (If it was, the result would have to be independent of ##\phi_0##.)
Try chapter 21 of Srednicki, draft version available here: http://web.physics.ucsb.edu/~mark/qft.html
I think the measure must not be invariant. If so, ##i \Gamma [ \phi_0 ] ## is independent of ##\phi_0##, and Weinberg mentioned about this point.
I have already read Srednicki book, but for me, that is not enough.
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
