Question about the property of PDF
The discussion revolves around the confusion regarding the probability P(X = 2) and its relation to the probability density function (PDF). It clarifies that P(X = a) equals zero for continuous distributions, but the case presented involves a discrete distribution with specific probabilities assigned to distinct values. The participants suggest that the question may contain a mistake, as it seems to imply a misunderstanding of the relationship between the cumulative distribution function (CDF) and the PDF. The presence of a step discontinuity in the CDF at x = 2 is highlighted, indicating that P(X = 2) can indeed be non-zero in this context. Ultimately, the conversation emphasizes the importance of recognizing the nature of the distribution when interpreting probabilities.
songoku
Please see below
P(X = a) = ##\int_{a}^{a} f(x) dx = 0##
Derivative of CDF = PDF
This is part of my note:
Now, this is practice question:
I want to ask why P(X = 2) is not zero, because from the note: P{X = a} = ##\int_{a}^{a} f(x) dx=0## ?
If I differentiate F(x), I will get f(x) which is the pdf, then using the pdf to find P(X = 2), I think I will get zero as the probability.
Thanks
Hi,
there is something fundamentally wrong with your relevant equation: the right hand side is zero !
(as you discovered :smile: )
Probability density ##f## is defined such that ##f(x) \, \bf dx## is the probability to find something in an interval [x, x+dx]
Since the probability to find something somewhere is 1, PDFs tend to be normalized:$$\int_{-\infty}^\infty f(x) \,dx = 1 $$ and that's what should help you find the answer...
[edit] adapt notation ##f## for probability density
Have you been introduced to the properties of the Dirac delta function ?
I must confess the given information : P(2) = 1/2 is highly confusing. You sure it's not F(2) = 1/2 ?
[edit] but that conflicts with ##F## given for ##x\ge 2## - - - is there an error in the problem statement ?
Advice: assume a value for ##a##, use the fact that ##F(+\infty)=1## and sketch ##F## and ##P##.
BvU said:
Hi,
Do you mean the formula I wrote in "relevant equation" is wrong?
P(X = a) = ##\int^{a}_{a} f(x) dx=0## is not correct?
No, I have not been introduced to that terrifying function
What I post is the exact question and up until this moment there is no revision to the question
I am not sure whether the question is somewhat similar or related to this one:
https://www.physicsforums.com/threa...e-distribution-function.1056469/#post-6957692
I can do the question in that thread but now I think about it, why P(X ≤ i) and P(X < i) is not the same and why P(X = i) is not zero? Because from the note, P(X < a) = P(X ≤ a) = ##\int_{-\infty}^{a} f(x) dx##
Thanks
I’m no expert but a couple of thoughts...
The given CDF consists of 3 'steps'. That means we are dealing with a system with 3 discrete ‘allowed states’ at ##x=-1##, ##x=1## and ##x=2## such that:
##f(x=-1) = p##
##f(x=1) = q##
##f(x=2) = r##
where ##p+q+r=1##.
Otherwise ##f(x) = 0##.
EDIT
I suspect (like @BvU) that there is a mistake in the question. If ##P(X=2) =1/2## should actually be ##f(x=2) = 1/2##, the question is then easily answered
(only simple algebra/arithmetic needed).
It is correct, but then what can we say about the given ##P(X=2)={1\over 2} ## ? When the relevant equation clearly states ##P(X=z) = 0 ## for any ##z## ?
Then the other thread is also a mystery to you ? Or do you understand that your PDF is the sum of three delta functions with different 'amplitude' ?
Fair enough,, but that doesn't guarantee that there is no mistake ... :rolleyes:
BvU said:
Advice: assume a value for a, use the fact that F(+∞)=1 and sketch F and P.
Thanks
Seems to me that one is still open too ...
Fine, but what happens when the CDF cannot be differentiated?
Because P(X=2) is given in the question and is 0.5.
Because the note only applies where the CDF is differentiable (and where the PDF is integrable). The CDF in the question clearly has a step discontinuity at ## x=2 ##.
Steve4Physics said:
##f(x=-1) = p##
##f(x=1) = q##
##f(x=2) = r##
where ##p+q+r=1##.
Looks good to me.
Steve4Physics said:
I suspect (like @BvU) that there is a mistake in the question. If ##P(X=2) =1/2## should actually be ##f(x=2) = 1/2##, the question is easily answered (only simple algebra/arithmetic needed).
I don't see a mistake - why do you think ## P(X=2) ## can't be ## \frac 1 2 ##?
Likes songoku, SammyS and Steve4Physics
There is no problem with ##P(X=2)= \frac 12##.
I messed up. I thought that the equation ## P(X=a) = \int_a^a f(x) dx = 0## (in Post #1) was part of the question. But it is not part of the question and isn’t relevant here (as we are not dealing with a continuous probability distribution).
EDITED
Likes songoku and pbuk
Ahh I see, so that's my mistake.
Not a mystery anymore (but I still don't understand about delta function and have not learned about it)
Thank you very much for all the help and explanation BvU, Steve4Physics, pbuk
