Question about thermodynamics first law
The discussion clarifies that the equation dU = TdS - PdV is not limited to reversible processes but is a fundamental relationship applicable to any thermodynamic state. It emphasizes that this equation reflects the physical properties of a material, linking changes in internal energy (U), entropy (S), and volume (V) between neighboring equilibrium states. The relationship is derived from the second law of thermodynamics, which establishes constraints on these state functions. Despite being developed from reversible processes, the equation's applicability extends beyond them. Overall, the key takeaway is that dU = TdS - PdV is a state function relationship, independent of the process type.
Clara Chung
I know that dS=dQ/T for reversible process,
is dU=TdS-PdV for reversible process only?
Science news on Phys.org
This equation has nothing to do with any process. It is a physical property relationship that must be satisfied for any material, describing the relationship between the mutual changes in U, S, and V between and two closely neighboring thermodynamic equilibrium states of the material. This constraint is imposed as a consequence of the 2nd law of thermodynamics.
Likes Clara Chung
Agree with Chestermiller, dU = TdS-pdV is nothing to do with the process, (reversible or irreversible), even though it is developed from the reversible process, since all of the qualities here are state functions. Therefore, they are just related to the state.
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
