Question about timevarient& invarient.
  • Thread starter Thread starter angel23
Y(t) = X(2t) is classified as a time-varying system because it does not satisfy the conditions for time invariance. A system is time-invariant if shifting the input results in an equivalent shift in the output, which is not the case here. The discussion emphasizes the importance of checking the definitions and applying them to determine the system's nature. The lack of parameters containing the variable t in the function does not automatically imply time invariance. Therefore, the conclusion is that Y(t) = X(2t) is indeed time-varying.
angel23
why is Y(t)=X(2t) time varient ??
AS you know Angel the rule here by the mentors are that we have to show that we tried doing it. So please show what is your approach and after that by the rule of this forum I can help you.
i looked at my function and found no parameters containing the variable t so i said it is a time invarient system..
am i right or wrong?
is there any other way i can use to check whether my function is time varient or time invarient?
FOR TIME INVARIANT SYSTEM
[ tex ] x_1(t)------>y_1(t) [ \tex ]
[ tex ] x_2(t)= x_1(t-T) [\tex] ---keep this equation same
x_2(t)------&gt;y_2(t) [\tex]<br /> y_2(t)=y_1(t-T) [\tex]&lt;br /&gt; &lt;br /&gt; If all these conditions are true for that function then YES its TIME INVARIANT else its TIME VARYING. So if you put Y(t)=X(2t) here and you will see that eqn (3) is not equal to eqn(4). So its TIME VARYING.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
