Question about transient temperature and pressure for air flowing into a box
  • Thread starter Thread starter Chiel555
In a perfectly insulated room with a vacuum box connected to it, the air will flow from the room into the box, leading to eventual equalization of temperature and pressure. The time it takes for this equilibrium to occur is theoretically infinite, as the changes approach equality asymptotically at a decreasing exponential rate. If the box's walls were to disappear instantly, sound waves would fill the room, creating a temporary disturbance until equilibrium is reached. The discussion highlights the complexities of transient temperature and pressure dynamics in a controlled environment. Ultimately, the nature of airflow significantly influences the rate of achieving equilibrium.
Chiel555
Hi all; i have some ( more) questions:
Imagine a room of 10 meters long, 10 meters wide and 5 meters high, filled with air
and a box of 1 by 1 by 1 meter, completely vacuum; the box is connected to the room and open so the air can flow freely from the room into the box;
both room and box are perfectly insulated on the outside so no heat and no air can escape
now suppose that de room starts with a certain temperature T and pressure P and the box with temperature 0 en pressure 0;
you would expect that in time the room and the box have the same temperature and after a time the same
pressure
what are those times ?; are they the same ?
Chiel555 said:
... the box is connected to the room and open so the air can flow freely from the room into the box; ...
It will depend on how "free" your "flow freely" actually is. In theory, the time will be infinite, because the temperature and pressure will approach equality asymptotically, as a decreasing exponential rate.
If you change the question to having the walls of the small box disappear in an instant, then the room will be filled with sound waves for some time, as the depression wave fills the vacuum at the speed of sound, and echos between the diagonal corners of the room. The question will then be, how quiet is equilibrium?
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
