I Question about weights using Chebyshev polynomials as quadrature
confused_engineer
Hello everyone.
I am studying this article since I am interested in optimization. The article makes use of Clenshaw–Curtis quadrature scheme to discretize the integral part of the cost function to a finite sum using Chebyshev polynomials.
The article differentiates between the case of odd and even number of collocation points. In equation 27 and 28 (fourth page), the case of N even is discussed. If N is even, then the N+1 collocation points, including 0, form a vector of odd length.
Then weights are calculated as ws=wN-s=... for s=1, 2, ..., N/2. Meanwhile, w0 and wN are calculated on a different way.
This in turn means that one of the elements is calculated twice, as shown in the following example:
N=6; N+1=7; N/2=3; s=1, 2, 3; N-s=6-1=5, 6-2=4, 6-3=3.
As you can see, the fourth element of the vector, number 3, appears two times. I find this weird. Can someone please tell me if I am understanding the article wrong or if this is intended to happen?
Thanks for reading.
Regards.
I do not see where the problem is. For ##N=6## we have ##w_0=w_6=1/35## and then formulas for ##w_1=w_5##, ##w_2=w_4##, and ##w_3##. Since ##s=3= N-s=6-3## and the formula for ##w_3## only depends on the given number ##N## and ##s=3##, where is it defined twice?
Likes confused_engineer
First of all, thanks for answering my question.
I am confused because the article tallks about ωs and ωN-s and I find extrange that following the paper one arrives to ω33=4/N*... for this particular example.
Therefore, I understand from your answer that ω33=4/N*... is the weight of the fourth element of the vector. I thought that since I had ω33, the middle element might have twice the weight.
Sorry if I haven't expressed myself clearly.
Thanks again for your answer.
No, it was only a way to avoid writing an extra line for ##\omega_{N/2}##. ##N/2 = N-N/2## for even ##N## so it is only defined once.
Then is all clear. Thank you very much.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
