A Question about Weinberg's GR book
LordShadow_05
TL;DR Summary
Why does Weinberg discard a term of the ricci tensor he should be taking into account in the post-newtonian approximation of fourth order?
To anyone who has studied Weinberg's book. Does anyone know why Weinberg discards the fourth order term of the purely spatial components of the ricci tensor? It's the chapter 9 (post-newtonian approximation) of his GR book. It doesn't make sense to me because he includes the R_{00} term of fourth order but not R_{ij}.
It seems that Weinberg's treatment reflects the physical hierarchy in gravitational systems: time components (energy) drive the dynamics while spatial components (stress) provide corrections. Including fourth-order R₀₀ but not R_ij maintains the appropriate balance between accuracy and computational tractability in the post-Newtonian framework.This is a standard and well-justified approach in post-Newtonian theory, used successfully in gravitational wave astronomy and precision tests of General Relativity.
Likes LordShadow_05
Ok, now I understand. Thank you very much!
The reason that ##^4_{R_{i j}}## is not included in the list (9.1.26) through (9.1.29) is because this list is meant to include only the Ricci terms that can be calculated from the list of affine connection terms given in (9.1.16) through (9.1.22) on page 215. Note how all the connection terms that appear on the right sides of (9.1.26) through (9.1.29) are in the list (9.1.16) through (9.1.22). At the top of page 216, Weinberg refers to the connection terms in (9.1.16) through (9.1.22) as the “known” affine connection terms.
You can show that ##^4_{R_{i j}}## depends on affine connection terms not included in (9.1.16) through (9.1.22), such as ##^4_{\Gamma^0_{0i}}## and ##^3_{\Gamma^0_{ij}}##. So, ##^4_{R_{i j}}## is not included in (9.1.26) through (9.1.29).
If you proceed through Weinberg’s analysis on pages 216-220, you will see that he needs only the Ricci terms listed in (9.1.26) through (9.1.29).
Likes jbergman, LordShadow_05 and Alien101
Oh I see. So the thing is that even if ##^4_{R_{i j}}## is of fourth order it doesn't contribute because we see that it is constructed with components of Christoffel's symbol that don't appear in the geodesic equation, so those components aren't measurable, right? I have calculated this component of the Ricci tensor including the "unknown" affine connection terms and I obtained the following:
$$^4_{R_{i j}}=\partial_j ^4_{\Gamma^0_{i0}}-\partial_0 ^3_{\Gamma^0_{ij}}+\partial_j ^4_{\Gamma^k_{ik}}-\partial_k ^4_{\Gamma^k_{ij}}+ ^2_{\Gamma^0_{i0}} ^2_{\Gamma^0_{j0}}+ ^2_{\Gamma^m_{ik}} ^2_{\Gamma^k_{jm}} - ^2_{\Gamma^k_{ij}} ^2_{\Gamma^0_{k0}} - ^2_{\Gamma^m_{ij}} ^2_{\Gamma^k_{mk}}$$
I find that this component of the Ricci tensor isn't only constructed with "unknown" affine connection terms but also with "known" ones. Then, why don't we take into account those terms which contain "known" affine connection terms?
Also, at the end of that same page (216) he uses the harmonic gauge ##\Gamma^{\lambda}=0##. For the component ##\lambda=0## he obtains the equation 9.1.35. For obtaining that equation he made use of the "unknown" affine connection term ##^3_{\Gamma^0_{ij}}##. So why can he use the "unknown" terms here but not in the Ricci tensor?
Thank you very much for your comment.
Edit: my formula doesn't show up and I don't know why. I have attached an image.
Tλλ
The objective is to determine the free-fall equations of motion to order ##\frac {\overline{v}^4}{\overline r}.## This requires knowing the specific ##\overset{\small N}{g}_{\mu \nu}##’s on the right-hand sides of (9.1.16) – (9.1.22). Specifically, we need to find these: ##\overset{\small 2}{g}_{00}##, ##\overset{\small 4}{g}_{00}##, ##\overset{\small 3}{g}_{i0}##, and ##\overset{\small2}{g}_{ij}##.
These ##\overset{\small N}{g}_{\mu \nu}##’s are determined from the Einstein field equations ## \overset{\small 2}{R}_{00} = -8\pi G \overset{\small 0}{S}_{00} ##, ##\overset{\small 4}{R}_{00} = -8\pi G\overset{\small 2}{S}_{00}##, ##\overset{\small 3}{R}_{i0} = -8\pi G \overset{\small 1}{S}_{i0}##, and ##\overset{\small 2}{R}_{ij} = -8\pi G \overset{\small 0}{S}_{ij}##, where ##S_{\mu \nu} = T_{\mu \nu} - \frac 1 2 g_{\mu \nu} {T^{\lambda}}_{\lambda}##.
Setting up ##\overset{\small 4}{R}_{ij} = -8\pi G \overset{\small 2}{S}_{ij}## would not help. It would result in an equation involving unknown ##\overset{\small N}{g}_{\mu \nu}##’s that we do not need for the equations of motion. So, ##\overset{\small 4}{R}_{ij} = -8\pi G \overset{\small 2}{S}_{ij}## is not going to be helpful in determining the ##\overset{\small N}{g}_{\mu \nu}##’s that we need.
##\overset{\small 3}{\Gamma^0}_{ij}## does not appear in the list (9.1.16)-(9.1.22). But this term is nevertheless needed in deriving equation (9.1.35), which can be used to help simplify (9.1.30)-(9.1.33). I don’t see any problem here.
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
